Question about Uniden Lands Phones
I cannot use my key pad to call after number is dialed and that makes all kinds of noice
  • 1 more comment
  • farrisfs Apr 22, 2010
    dect2080
    i can dial out but cannot transfer to answering parties and the dialing numbers are what makes the noise
    model 2080 i can dial out but cannot tranfer to anyone after they answer and the dialing out is slow and noisy
  • 1,284 Answers
Hi, what you are currently experiencing is either a bad keypad as a result of too much usage or a faulty glass ic which in both ways needs to be replaced.
Before that you can first of all try cleaning keypad button interface which may be dirty but if after cleaning, it is still not working, then you carry out my first step..
Take care
Posted on Apr 22, 2010
  • 2,335 Answers
What model Uniden Phone are you having trouble dialing?
The more information you provide, the more accurate we can be with our solutions.
If if looks like this model, your phone is from the DCT758 series, I do have the manual handy. I could walk you through pairing the phone to the base station, which would account for not being able to dial out, although I am not certain about the 'noises' being a symptom of that problem.
Please check and post your model number if possible.
I hope that helps.
________________________________________
Uniden DCT758 User Manual Here.
  • Paul Sager
    Paul Sager Apr 22, 2010
  • Paul Sager
    As long as your handset is in privacy mode, other handsets can’t join your call or make any calls of their own: their displays will show UNAVAILABLE.
    1. While on a call, press [Menu/Select].
    2. Select CALL PRIVACY. PRIVACY MODE ON appears in the display for two seconds; 'P' appears and remains in the display until the feature is turned off.
    To turn privacy mode off, repeat the procedure listed above. PRIVACY MODE OFF appears.
    Transferring a Call
    You can transfer a call from one handset to another. The handsets must be currently connected to the same base.
    1. During a call, press [Clear/Int’com].
    2. Use up or down arrows to select the handset you want to transfer the call to, and then press [Menu/Select]. Select ALL to page all other handsets. The call will automatically be placed on hold, and a paging tone sounds. Tocancel the transfer, press [ /Flash] or [Speaker].
    3. When another handset accepts the transferred call, you will be disconnected. If you want to rejoin the call, press [ /Flash] again or [Speaker].
    If your dialing is 'slow and noisy' it may be set to pulse dialing instead of tone dialing; this would make the phone send many clicks instead of tones.
    1. Press [Menu/Select]. Select the GLOBAL SETUP menu, and then the DIAL MODE submenu.
    2. Scroll [up arrow] to highlight TONE.
    3. Press [Menu/Select]. You will hear a confirmation tone.
    If the dialling tones are regular, but just too loud for your tastes, adjust the volume of the handset by pressing the down arrow on the handset while on a phone call.
    I hope that helps
How to access voicemail when dial pad is nessed up
You'll have to do that from another phone the process may vary based on your carrier but usually you dial your number and let the voicemail start. Press THE # key then enter your pin when prompted
Aug 15, 2016 | LG G2
In my mobile numbers are getting automatic dialed
Turn on the lock "key pad" turn of automatic "redialing"
Jun 09, 2012 | Samsung star II duos GT-C6712
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
When I jostle the phone it will dial a number from my contacts. Is there a way I can disable the dial pad?
pressing the Home Key then the Space Bar will temporarily lock the key pad, can be un locked be pressing the Left Soft Key
Sep 14, 2010 | Motorola Mobility Moto Q
Nokia N73 number 2 key not working.
hell there! I want u to try this small antidode get the key pad membrane cleaned which is under the key pad . coz some kind of carbon forms after a period of time or liquids to can cause this too.
lastly if no change change the key pad membrane .
Get a technician to do this for u
have fun
good luck
Sep 08, 2009 | Nokia N73 Cellular Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Dial out problem
you just have to change the key pad and dry the inside of the phone.
Feb 09, 2008 | Motorola Mobility RAZR V3
KEY PAD ON FAX MACHINE WON'T WORK
Have you programmed the  'rapid' (one touch) buttons or the speed dial numbers? (print a report of stored numbers to be sure)
Is machine set to fax mode?
Oct 15, 2007 | Brother IntelliFAX 4100 Laser Fax
How do I set up speed dial
Lift up the cover over the key pad and the is a key marked data registration. push it then push the set key. using the arrow keys scroll down to set up machine then push set, and find the speed dial feature again push set enter your number push set and go on to the next one. Good luck it is kind of confusing
Jun 14, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Lands Phones Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
