Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
Will not power on
Press on button and I hear a click as if it is trying to power on and then another click with nothing happening. The red stand-by/timer light blinks. I unplugged TV and waited 5 minutes and tried again but same thing happened.
  • murr8 Apr 22, 2010
    I'm not sure I understand what you mean by blink. I have a KV-32HS420 wega. When I turn it on there is a small "stand-by" red light next to it. It is blinking 6 flashes if that is what you mean. thanks for your assistance.
    ED
  • atelier mj
    atelier mj May 11, 2010
    HOW MANY BLINK
  • 70 Answers
For that model 6 flashes mean LOW B+ (OVER CURRENT OR OVER VOLTAGE. Maybe cause by a short in +5 volt on AY, BY or MY board.
Posted on Apr 23, 2010
    New Friend:
  • 106 Answers
Line o/p transformer & transistors are gone ...take help of a tech person to change them
Where i can find elecrical wiring diagram
When you try to start the bike, does anything happen? Noises? Clicks? Or is it silent and nothing happens? If you hear a click or it try's to start but doesn't turn over. If nothing at all happens when you hit the start switch then you most likely have an electrical issue, versus if you hear the starter click or try to start to bike, then that would mean a mechanical issue.
May 14, 2014 | 2008 Peugeot Geopolis 400
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Mar 26, 2014 | Televison & Video
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Black screen no cursor no keyboard use
When you powered on the machine did you hear any beeps, hear the fan running, the disk drive running, lights blinking, hear the cd drive click, see the light on the cd drive door for a second or two when it clicks? If these things are happening you are getting power. If not, your problem might be with your power supply, hard drive or motherboard. Remove the power cord, then press and hold the power button for 30 seconds, then plug it back in and press the power button. if it boots you had a static charge. If you get nothing at all but a silent system your power supply is bad. If it sounds like your computer is running but you can't see anything on the screen you might have a problem with your screen or video card. If you have another monitor try using it and see what happens. if it works so you can see things then your monitor was bad. If it does not work with another monitor but you still hear fans, and see lights and hear the disk drive spinning, then your video card is probably bad.
Mar 17, 2012 | Gateway Computers & Internet
Nothing happens only power button lights or turns off
Count the number of flashes for the red power button. I'm not a Hitachi owner, but you can track one down here on fixya and they''ll give you more info. One of the internal components have failed and is keeping the power supply unit from firing up. Do you hear a relay click when you try to turn it on? If so, how many times does it try to fire up?
May 23, 2009 | Hitachi 57F500 57" Rear Projection...
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
