I have a fiberglass circular home AC unit that has a water leak. What do I seal the pan with?
  • 43,501 Answers
Clean and then dry the pan with a hair dryer... then take clear silicone caulk and seal the hole or crack...then let the caulk setup for 12 hours before starting the unit and getting it wet...simple fix...
Have done this many times...
heatman101
Posted on Apr 23, 2010
I have a 2013 keystone cougar 327res and the belly pan is full of water...where should i look for my leak?
This is not just for your camper, but general troubleshooting.
Drain the water from the belly pan. Hook up water supply to shore water source. With water source turned on, allow some time, 1-4 hours, and check if water has returned to belly pan. If water is present then the problem is with the fresh water system. If no water, either it is a small/slow leak or the problem is not with the fresh water system. Next test the grey water tank by pouring some red food color into the shower or sink drain. Flush it into tank with water. Again, wait for some time, maybe over night, and then check for red water in the belly pan. It may take longer for the leak to appear as the grey water tank does not have pressure. If no water, check the black water tank with green food coloring and same technique. If there is colored water, red or green, in the belly pan, then the leak is with associated with the grey or black water tanks. If no water is present after these tests, then the leak may be very small and it may take days or weeks to have water re-appear. In any event, clear water is fresh water system, red water is grey water system, and green water is black water system. With any of them, checking the tanks themselves and all pipes and connectors to/from should find the leak source. The last possibility is that water is entering the belly pan from a roof or vent leak. Check to see if water returns to belly pan after a good rain. If so, the water may be clear or slightly dirty. If it is a roof leak, I have found the best repair is to use Peel and Seal roll roofing It is light weight laminated aluminum and self sticking. Cutting and applying narrow strips 4-6" wide, will seal any caulked area. It costs $95 (3' x 33') at Lowes. A 30" motor home can be completely covered with three (3) rolls, in half a day. I have re-topped 5 motor homes (one 7 years ago) and no more leaks on any of them. The product was developed to seal the roofing joints of mobile homes. Topping should last 15+ years.
Oct 05, 2016 | Keystone 2013 Cougar 327RES
My coleman air conditioner 7300 series is leaking water on the inside
Water in an air conditioner is generally condensation building up on the indoor coil. This happens when the temperature of the coil is below the current dew point of the atmosphere. You have possibly two issues going on.
1) the condensation drip line, which carries the water to the outside is blocked or disconnected (most likely blocked with wet dust build up etc) and can typically be cleared by using an air hose to blow the blockage clear.
2) excessive water can be an indicator that you may have a slow leak in the refrigerant system. reduced pressures will lower the temperature of the coil causing it to condense more water, more frequently. While you might enjoy the seeming better performance of the unit, if there is a leak it will eventually reach a point where the water will freeze(cutting off the air flow so no cooling) and eventually stop working altogether. Have a certified technician check your system for leaks. Remember that most rooftop units use R-22 refrigerant, not R-134a automotive refrigerant. The wrong refrigerant in the system can be very damaging to components and seals, and can cause the unit to function improperly.
Jun 19, 2014 | Dometic Rooftop RV Air Conditioner
My ac unit is leaking through the coil box, I cleaned the drain, but it still leaks from the side of the box. Could it be cracked? the unit is 9 yrs old
Could be a cracked condensate pan. this may require replacing the pan or there are sealing sprays on the market which you can buy at HVAC stores.
Dec 11, 2012 | Weather King Heating & Cooling
Water leaking at bottom of cylinder.out side of pipe at bottom.
Depending on age and condition, If you don't see any noticable leaks where pipes are fit on top of the tank, you will more than likely have to replace the heater. Try turning the power off to unit and remove the inspection plate(s) on the side. See if you can tell where the water is coming from. If you see it is leaking around the element(s), you may want to try to remove the element(s) and apply teflon tape or sealant to the threads and re-install, do not over tighten. You may have a crack in the fiberglass tank. Water is leaking down into the metal tank which is a protective cover for the fiberglass tank that stores the water. The pipe at the bottom is probably the drain for the tank. If you are going to try to re-seal the elements, you will definately have to cut the power nad drain the tank first.
Aug 22, 2011 | Water Heaters
I HAVE A 5000 BTU G E WINDOW UNIT I PURCHASED AT LOWES LAST YEAR, IT DRIPS DOWN OVER MY PATIO IS THERE A WAY TO INSTALL A DRAIN ?
a plastic pan under the unit with some small hose can divert the water elsewhere. use silicone calk to seal the hose in the hole you drilled in the bottom of the pan NEVER DRILL THE PAN OF THE AC UNIT ! use something to catch the water.. if you drill the unit, you take the chance of hitting one if the AC lines !!! there no fix'n that
Jun 06, 2011 | GE AEV05LN Air Conditioner
The tank on the mastercool is beginning to rust out. Is there an available fiberglass insert for these tanks, or do we need to use mesh and mold it in place?
I have wondered this myself. The Mastercool has inherent weaknesses in the pan where the metal sides and bottom tray meet. Of course they are not manufactured with a fiberglass tray because they would last too long and therefore reduce profits for replacement coolers. I have found that the bottoms of the pans rarely rust because they are constantly under water, not exposed to the air, and also accumulate a buildup of minerals that actually protect the metal. It seems that water gets in the seams and along with the exposed metal at the waterline, rusts out primarily in the end corners. I know of no fiberglass insert but am currently working on three rusted units by using fiberglass cloth and resin and filling holes with good ol' regular automotive Bondo. I am particularly making sure that it is totally sealed so not water can get past the pan. It will take a year or two to find out if this works.
I have also considered cutting off the old pan and having a local HVAC shop fabricate a new one using stainless steel or aluminum. This might be a little costly but would save time compared to reworking the old one with fiberglass cloth. I have been successful in obtaining used metal including SS sheets from the salvage yard very economically. The cost would be in the simple fabrication of the tray and any welding required to make it watertight. I might try this down the line if the fiberglass retro doesn't work.
May 01, 2011 | Mastercool 67471 Evaporative Cooler Air...
I suspect water is seeping in under my AC unit...
The roof A/C unit has a foam rubber seal/one piece gasket that fits around the part you see inside the coach but must be put in pklace before the unit is inserted in the roof opening. Replacing is relatively easy but you will need to remove the interior trim Disconnect the wiring from the coach to the unit and remove the four bolts holding the unit in place. Then lift out the A/C.to replace the seal. They do leak because of age and compression by units weight. Good Luck
Jan 28, 2010 | Dometic Rooftop RV Air Conditioner
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Leaking air conditioner unit
I suppose that the water is coming from the unit where the blower motor is. Condensation is created by the evaporator coil while its running and is suppose to drain into a pan under it and through a pipe to the outside. This pipe could be stopped up. The easiest way to fix that is to blow air through the pipe from the outside. It probably comes out close to the outside unit. It could be that your inside filter is dirty causing reduced air flow and making the evaporator freeze too. Change the filter. That may help. There are other steps that you could take if these don't help. Contact me by email if you need to. Cant run over there because I'm in Missouri but may be able to help in a chat room. kstfas@yahoo.com
Aug 15, 2007 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
