Question about Peavey Pv 2600 Power Amplifier
What is the best suited power amp for the Peavey PV14 mixer board?
    Genius:
  • 1,066 Answers
That depends on your speakers, not the mixer. the amp should be matched to the speakers, in watts and in ohmage. for example, 400 watt, 8 ohm speakers should get an amp that runs at 350-500 watts at 8 ohms.
Posted on Nov 30, 2010
The signal lights all flash on and off and the unit will not power up..
This is a common issue with peavey mixers and generally speaking could be addressed by checking the opamps supply voltage which should be -15V at pin-4 and +15V at pin-8, this should help to troubleshoot the issue, let me know to help improvement.
Oct 19, 2012 | Peavey Electronics Peavey PV14 Mixer
Slide pots for PV14 mixer
The pot needs to be cleaned. Get a spraty can of DeOxit 5. Spray it into the track and move the slider up and down a number of times. If that doesn't fix it, replace the slide pot.
Jul 30, 2012 | Peavey Electronics Peavey 00512140 PV 14...
How do i hook a peavey fx24 mixer to a Peavey xr8600 with out going through the 8600's mixer? I am wanting to use the 8600 to power my mains and use another amp to power my monitors. can i do this?
You CAN drive the power amps from the main amp inout jacks BUT the rest of the inout of the 8600 would be dead then. You can connect the L and R from the FX24 to either the media RCA jacks or into the channel9/10 jacks. FOr the latter, use TRS cables. Leave the two selection buttons in the up position.
Sep 21, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey pv14 right side stop working all of a sudden how do i fix it?
you could have blown the output on that side,, here are some other things you may need to know about that mixer http://bose.infopop.cc/eve/forums/a/tpc/f/8566055944/m/3281007943 I have seen the manual for this unit in the past and it really doesn't give many details of what all can be used for this mixer,, However that seems to be par for most unpowered mixers, I do know that if your using a mic with it,, its very choosy on which ones work , and those that have issues
Sep 11, 2011 | Peavey Electronics Peavey PV14 Mixer
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
Apr 30, 2011 | Peavey Electronics Peavey 00512140 PV 14...
Connecting unpowered monitors to the board
You will need toput power amplifiers that drive the speakers and then connect the board to the power amps. Use BALANCED interconnects for this and power the board from the same receptacle or surce as the amps.
Feb 28, 2011 | Peavey 16FX 16 Channel Mixer
I have 2 peavey 2600 amps with 1 pv6 mixer wanting to run subs off 1 amp and sp2s off other amp but only have 1 main output on the pv6 mixer whats my solution
you can run one amp from the main out puts and the second amp from the CTRL Room out puts. The CTRL ROOM are outputs that are linked to the same bus as the master fader. This will work fine...
Best of luck
Sep 02, 2010 | Peavey Pv 2600 Power Amplifier
I need a on & Off button on a pv 2000 peavey amp
Go to the Peavey website. Best to order parts from them or one of their dealers. www.peavey.com/support
Mar 21, 2010 | Peavey 32fx USB 32 Channel Mixer
Peavey Pv 2600 Power Amplifier Logo
179 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
