Question about Lexmark X3350 All-In-One InkJet Printer
Printer unable to communicate with computer.
I am trying to get my printer to work. All drivers etc. downloaded. When I try to print, I get a message "Communication Not Available." Printeris unable to communicate with computer. I've checked all the connections, restarted, etc., but no luck. I've been using this printer for a couple years without any problems.
  • Lexmark Master
  • 5,479 Answers
Are you using the wireless network printer function or is the printer connected by a USB cable? If you are using the wireless network, launch the printer's Wireless Setup Utility and run through it. (Check for problems with IP, signal strength etc.)
For USB, try resetting the printer (unplug it from the wall for 10 seconds). Check that the computer is looking for the printer on the correct port. Click Start > Settings > Control Panel. Double click on the Printers folder and right click on your Lexmark printer. Choose Properties then click on the Ports tab. Check that one of the USB port options is checked. (If you have a newer OS, Start > Devices and Printers and then right click on the printer.) Also try a new USB cable and a different USB port. If you have a print server or USB hub, try a direct connection.
I hope this helps.
Posted on Apr 22, 2010
Ihave a dellp513w and some how i put the disc in that came with it trying to get it connected to the computer so i'am able to print from the computetr and it want work. The disc want connect to the...
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Uninstall the printer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
With your computer online, Insert the printer disk or try using the drivers located at...
Dell P513w Wireless All-In-One Printer owners thread
You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block printer communications.
Rick
Apr 19, 2011 | Dell 948 All-In-One InkJet Printer
Printer not printing
try to reinstall drivers for printer and if not working reinstall software that came with it. u can also go to hp.com and download newest drivers for ur printer. also make sure wires are connected properly and that ur pc detects it.
Dec 13, 2009 | HP OfficeJet J4580 All-In-One Laser...
Will not print anything off computer
if your using a usb try to connect it other usb slot see to it that your computer recognized it and you install the appropriate driver for your printer. good luck!!
Oct 07, 2009 | Office Equipment & Supplies
Lack of communication
http://www.computerhope.com/issues/ch000250.htm
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 24, 2009 | Dell 966 All-In-One InkJet Printer
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmark 5410 will not communicate with my mac or pc laptops
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Prem
Mar 02, 2009 | Lexmark X5495 Printer
Lexmark printer not communicating w/ computer.
Here is the link for the download to obtain the driver for the x2500 . Install it and see if all your printer  problems might not go away
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Jan 20, 2009 | Lexmark Z600 InkJet Printer
Unable to print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
Vista
Have you tried turning off your firewall?
That may be the issue.
FIrewalls will block printers. Can you ping the printer and not print to it?
Feb 12, 2008 | Office Equipment & Supplies
Lexmark X3350 All-In-One InkJet Printer Logo
244 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
