Question about Asko D1716 Built-in Dishwasher
How do I remove the cerculation pump on an asko asko Dishwasher D 1716
  • behrenbruch Apr 23, 2010
    When I bench test the circulation pump On my asko D1716 dishwasher it seems to work good but when I put it back in and running and I open the door the spray arms are harddly turnning
  • Asko Master
  • 2,605 Answers
Hello, With the right technique it isn't too bad, but it does require removing it from the cabinet/cupboard. This is what I do. FIRST**Turn off the power at the main service panel or unplug the unit.** Shut off the water and undo the water supply and drain hose. Remove as much water from the sump well as possible because you'll need to lye the dishwasher on its front ( remove any dishes inside and also get some towels or a blanket to lay it on so you don't damage the front panel or control's ). Once you have the unit out and face down, you'll see the back of the circulation motor&pump assembly...this is where it gets a little tricky, but I've done plenty and will guide you through. The clamps holding the pump hoses in place are "one time" clamps so once removed they'll need to be replaced with narrow "worm gear" clamps when installing the new pump assy. Undo the wires at the side of the motor ( A good idea would be to take a picture or draw a diagram, the picture is likely better...in my case at least ). Hopefully from here you will get the new one in. Let me know how you make out, I'll watch your post. Good luck. Macmarkus :)
Posted on Apr 22, 2010
Testimonial: "Yhanks for the info now I need to decide new washer or fix rhis one any recomondations on a new one."
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Apr 23, 2010
    Hello again,
    I'm not surprised by that really. Often the motor will seem to work ok, but yet the wash impeller is spinning free within the housing and when the water is present cannot "pump" sufficiently. I find mostly the impeller is busted in fact, usually due to the ball bearings from the top rack falling out of the holders and into the pump housing. They are not serviceable sadly, you'll need to replace the entire motor&pump assembly, Asko part # 80-570-81 for your model 1716 and quite pricey at around $350USD.
    Let me know how it goes or if you need any more help.
    Good luck.
    Macmarkus :)
  • Mark MacDonald
    Hello again,
    Good luck.
    Macmarkus :)
  • Mark MacDonald
    Sorry for the double post, I accidentally hit "submit" twice. Still getting used to this "iphone" touch screen thingy.
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 24, 2010
    Well if it where me and the other component's of your Asko are in good order I would repair it however, that's not what you asked so...recommending a new unit can be difficult. I'll start by saying my number one choice would be between Asko or Meile. The list of ones I would avoid like the plague is longer. Those are absolutely Samsung, LG, GE, Smeg, and Firigidaire/Electrolux. In fact the only machine with a familiar name in north america I will recommend is Whirlpool, which also manufactires Kitchen Aid, Maytag, Inglis, Estate, Roper and many Kenmore ( careful VSA use the Estate name as well and they are built in New Zealand & some Kenmore are built by Frigidaire/Electrolux ).
    Having said all that I will also add it really depends on what your needs are too. A growing family ? Single ? House of two adults ? A bunch of bachelors...hire a maid, ha ha ! I also suggest some kind of extended warranty no matter what you purchase, most units only come with 1yr. warranty and it is relatively inexpensive ( $50 - $ 100 a yr. depending on model & provider ) and many machines rely on electronic component's and use more & more plastic parts as is to be expected to keep the prices down.
    I don't know if this is of any help to you or not, but I just don't feel completely confident recommending anything nor do I believe any of the consumer report info...not since I was informed one of there bases for gathering the ratings.
    Hope it gets you started however. Good luck in whatever you decide.
    Macmarkus :)
My asko dishwasher D 1716 is leaving a white film on my glasses and other dishes. I have added Jet Dry but it has not helped. Also sometimes water leaks under the handle and runs down the front of the...
Hi
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Asko D1716 Built-in Dishwasher
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
The spray arms on my Asko 1716 dishwasher do not turn - water enters the unit and drains easily, and the heating element also seems to work. The filters and sump are clear, as are the air gap and the holes...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, as you mentioned. What you may not know, is the impeller itself is not serviceable, the entire motor/pump must be replaced unfortunately.
Before declaring it is indeed a motor/impeller issue, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump obviously it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump or severed somewhere between the motor and control, maybe where the door pivots during opening...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet. Check those other possibilities first and tell me what you find.
I'll watch for your reply.
Regards,
Macmarkus :)
Mar 09, 2011 | Asko 1375 Dishwasher
The pump on my ASKO 1716 dishwasher will not stop running. Previous to this it did not always pump out completely. Simple fix or big $$$?
Simple fix. It appears that your anti-flood feature has activated due to water pooling under the tub of the machine. You may be able to remove the water yourself or you may need help. If you want to try to remove it yourself you will need a syringe with a tube attached and you will have to get under the drum. Joe
Mar 25, 2010 | Asko D1716 Built-in Dishwasher
I have an ASKO D 1716 and it has stopped draining....
Here is the manual for your dishwasher:
http://194.14.129.136/brandsite/DocumentOpen.aspx?did=3857&mid=43&lid=2
Go to page 9 of the manual and it shows you the steps to take when your dishwasher has stopped draining. Its the section that says "Dishwasher does not drain properly".
You may have to check your dishwasher filters for clogs and if you get that far in the troubleshooting process, it shows you on page 6 & 7 how to check those filters for clogs.
Aug 28, 2009 | Asko 24 in. 1585 Built-in Dishwasher
Asko 1475 dishwasher - won't wash. Circulation pump?
Check your drain. It is dual purpose. It not only drains but, it also recirculates the water doring the cycles.
Aug 10, 2009 | Asko Dishwashers
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Apr 04, 2008 | Asko Dishwashers
Asko D1716 Built-in Dishwasher Logo
579 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
