Question about Garden
Gas is getting in oil when it sets. i changed the oil and mowed lawn and a week later went to mow lawn and gas was in oil .at least a quart of gas. rolled engine over and gas came out of muffler
  • 23 Answers
It maybe your carbs seat inside of it sometimes they will leak and run into the motor
Posted on Apr 22, 2010
What do i do i put gas in oil tank self propelled snapper?
If you did not try to mow the lawn, but shet the motor off before there was a loud KA BOOM.
If not, it is time to consider a new motor.
Otherwise just drain the crankcase like you would to change the oil.
If you have a friend that could help tilt the mower so almost all the gas is drained.
Now, put oil in the motor, 40 wt because there will still be a little gas left in the motor and when you mix gas and oil the gas is absorbed by the oil and the oil will thin out.
DO NOT! start it up and rev up the motor. You want to let any remaining gas to be taken up by the oil. Run around your lawn a few times at a moderate speed WITHOUT the blades engaged.
After this you can mow the lawn, at a moderate throttle setting, then drain the oil and fill it with the oil your owner's manual says to use.
Or just put around your yard for 30 - 40 minutes, then change the oil.
The above will only apply if you didn't mow until you had flames coming out of the exhaust and banging, knock ing noises were coming from the motor.
Jun 04, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Some water got into my gas can and I put the gas in the mow unaware of it. I mowed for about 30 to 45 minutes when the mow's engine begin to make a popping sound. IWhile draining the gas tank and...
If there is gas in the oil you drained from crankcase the carb is really dumping fuel(did you see black smoke?) If your carb has a drain plug drain it. If not you will have to take off the carb bowl and clean it. Check float operation, turn on fuel work float by hand to make sure gas shuts off when float rises to level position. If not may need needle and seat kit. Or adjust float.
Sep 28, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Aug 21, 2009 | Garden
White smoke
White smoke is most likely cause there is to much in the engine.. Only takes about half quart.. Clean with degreaser and garden hose on the outside..
Jul 04, 2009 | Garden
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Open Questions:
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
