Question about HP Photosmart C6180 All-In-One InkJet Printer
The printer continually reboots
Since about 5am this morning, my HP seems to be caught in a loop, continually restarting. I've tried unplugging it, disconnected the network cable and plugging the power cord into a different outlet.
Boba
  • 64 Answers
SOURCE: ati2dvag caught in a loop
Boot to safe mode and uninstall the ATI drivers, then reinstall the lastest one from ATI. Preferrably, the new catalyst driver. also if this is any help: http://www.google.com/search?hl=en&...oop&btnG=Search Good Luck
Posted on Apr 17, 2006
SOURCE: hp officejet d135 series printer
Could be the printer carriage is binding, oil the rail and try again.
Posted on Nov 28, 2007
samisam
  • 106 Answers
SOURCE: Toshiba Laptop will log on caught in loop
We are an authorized Toshiba & Sony ASP. you may contact us as well.. We're quicker usually... let me know if you require contact info.
Posted on Jun 15, 2008
  • 8 Answers
SOURCE: Vista in Updating Loop 3 of 3 0% keeps rebooting.
nope it will allow the computer to fix itself not data loss at all. I've had to do this many times before. just try it and tell me your situation when you are done.
Posted on Sep 08, 2008
amusedgeek
  • 787 Answers
ati2dvag seems to have a problem with XP SP3
I don't know if you have SP3, but if you do, try rolling back to SP2
Method 1: Use the "Add or Remove Programs" item in Control Panel
1. Open the Control Panel
2. Select Add Remove Programs
3. Click to select the Show Updates check box.
4. Click Windows XP Service Pack 3, and then click Remove.
5. Click Finish to restart the computer after the removal process is complete.
Method 2: Use the hidden $NtServicePackUninstall$ folder
1. Click Start, click Run, type c:\windows\$NtServicePackUninstall$\spuninst\spuninst.exe in the Open box, and then click OK.
2. When the Windows XP Service Pack 3 Removal Wizard starts, click Next.
3. Follow the instructions on the screen to remove Windows XP SP3.
Method 3: Use the System Restore and select a restore point prior to SP3
Posted on Oct 10, 2008
Just installed windows 7 home premium, and it installed the drivers for my d7560. I printed something and now its caught in a loop, printing some junk text at the top and bottom of a page. I've unplugged...
hi it seems that printer is not able to take the proper signals from the computer , it means either some files have gone currupt, IN order to resolve this unplug the printer, uninstall the printer utility
1. click on start
2. go to control pannel
3. click on add remove programs.
4. select the printer utility and uninstall.
once it is done restart the computer, and reinstall the printer utility from the disc provided by the manufacturer .
this will surely resolve the issue .
Sep 15, 2010 | HP Photosmart D7560 InkJet Printer
My HP C6180 is caught in a start up loop
Do the following with a USB connection if possible.
You will need to completely uninstall the application ad drivers (see below) tehn reinstall the driver & application. You can download the latest version from HP Support at the following link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1153494&lc=en&cc=us&dlc=en&lang=en&cc=us
Make sure that you chose and install the correct version for your operating system.
If this persists then it would be a very good idea to uninstall the HP drivers and application then to run a Registry clean using the Ashampoo toll (free of charge for 30 days from www.ashampoo.de) to make sure that all instances of the driver and application have been removed so as not to cause any contention between drivers and applications. Then reboot the PC and reinstall the application from scratch.
Sep 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6150 Printer that turns off then back on repeatedly
Please DON'T keep posting messages that say "I had the same problem..." Those are useless!
If the software resets don't work, it's possible it's an electronics problem. Here is a repair note that worked for me:
http://www.fixya.com/support/t5821942-hp_photosmart_c6180_continually_powers
Jun 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Will not print! was working fine and stopped?
go to start>>control panel>>adminsitrative tools>> services
right click on printer spool and select stop.
restart the printer. restart the printer spool.
May 14, 2009 | HP Officejet 6200 All-In-One InkJet...
HP C6180 loop - turns off and on
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the Printer was having.74b7f9c.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these.
Dec 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer turns on, then goes off... Seems like its in a loop
Hi tommilligan,
unplug the power cord from the printer and press and hold the ON button for 10 secs and try connecting to diffirent wall outlet directly.
regards,  raj_p5983
Nov 22, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ati2dvag caught in a loop
Oct 05, 2008 | Toshiba Satellite A105 Notebook
"Error 1068 Could not start the Printer Spooler on local Computer"
http://www.usa.canon.com/consumer/controller?act=DownloadDetailAct&fcategoryid=357&modelid=10238 Above is the Canon site with the newest drivers available. Download them and install them. First "delete" the printer from print properties. Unplug the printer from the wall for a few minutes and shutdown the computer. Plug the printer in and reboot the machine. Install the new drivers. You are in a loop. definition of LOOP: see LOOP. Let me know what happens. Good Luck, Tim
Feb 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
These kind of problems can be caused by a number of different things, from software to dodgy ram, PSU etc etc. I'll assume you've already done a virus and adware scan-if not, do it now. If that doesn't work, let's start with the easiest to diagnose and fix-the device driver itself. Download the latest version of the Ati catalyst driver from Ati. Uninstall the existing driver(Assuming you're using Windows XP, Start>Control Panel>Add/Remove Programs, then find the Ati graphics driver on the list and remove it), remove the grapics cards entries from Device Manager(Start>Control Panel>System>Hardware>Device Manager, then click the cross next to "Display Adaptors", right click and choose "uninstall"), and reboot into safe mode (tap F8 at POST screen). Run drivercleaner in safe mode (you can download it from here): http://www.driverheavendownloads.net/ then reboot, cancel the "Found New Hardware Wizard" which pops up when you restart windows, and run the new driver installation program.
Apr 12, 2006 | Toshiba Satellite M55-S135 Notebook
HP Photosmart C6180 All-In-One InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
