Question about Black & Decker Garden
Broken Edge Guide
I have a Black & Decker GH400 12'' string trimmer. The part I cannot buy due to obsolescense is 385018-00. This part is the edge guide. I don't know the dimensions to attempt bend up my own. Do you know these dimentions? Can you help?
    New Friend:
The diameter of the Black&Decker GH400 edge guide is 1/8". I know because I have the same problem and a small piece left from the original. Trying to find a new one is quite the quest.
Posted on Jun 02, 2015
3 Suggested Answers
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
  • 18 Answers
SOURCE: operator's manual for black and decker string
copy and paste this url and you can print it off at your home or office. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90556296,GH1000.pdf
Posted on Jul 08, 2010
Black decker instructions
go to user guide on line.
Aug 12, 2014 | Black & Decker Garden
My grass hogger line extending unnecessarily and never get line short ( i meant extra line never get cut off. I think i have two problems here Why line is extending unnecessarily? & why it's...
If you look closely inside the shield, at what would be the leading edge as the string approaches, you should find a little cutter that trims the line if it is too long. This can get dull. I have had to sharpen the one on my B&D with a file before.
Sep 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
I have a Micky Mouse of a Black and Decker grass strimmer. The line breaks every time I use it for more than 10 seconds, the string is wound in the right direction and threaded through the hole in the...
Sounds like you may have lost the little metal grommet that should surround the hole that the business end of the string comes through. This grommet is usually aluminum because it is a very good heat conductor. What happens is that the string rubs very hard against the edge of this hole, which heats up the string in that one little spot enough to melt it. If the hole is only plastic, it cannot dissipate this heat. The grommet dissipates that heat and the string doesn't melt. I don't know if you can buy a replacement grommet. You might be able to a generic grommet like the kind sold for tarps. Or you can replace the whole part that should have the grommet in it.
May 25, 2010 | Black & Decker String Trimmer Cordless 12"...
The edge guide on my Black and Decker LE750 has worn out!
Exploded views (Printable) and parts can be found HERE.
Hope this is helpful,
Dolf-
Oct 18, 2009 | Black & Decker Le750 Lawn Edger
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Need manual for edge hog
you can buy it from amazon.
http://www.amazon.com/Black-Decker-LE750-Electric-Landscape/dp/B00004DTNH
thanks.
Jun 09, 2009 | Black & Decker Le750 Lawn Edger
Step by Step spool filling on my NEW Black & Decker GH700
Check the bottom of the spool. See the pattern that looks like a circular saw blade. Ensure that the raised edges, do not have any broken/missing sections. Also, check that the pivot lever in the cap, moves freely and engages the space between the same, saw-blade-like edges in the spool correctly. If there are broken/missing sections of the spool, replace the spool with a good one.
Apr 29, 2009 | Black & Decker String Trimmer Cordless 12"...
How do I get my Black and Decker 12"bump feed trimmer/edger out of the groom position and into the edge position? My boyfriend misplaced the instructions to our new edger and I can't figure it out.
The handle/shaft is in two parts. By grasping the upper part of the shaft with one hand, and the lower part with the other, you can move the two sections slightly apart, then twist to turn the trimming end 180-degrees.
Sep 15, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
216 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
