Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Power on - Screen Black non responsive
The power light is on however the screen is black and the menu button on the remote or on the TV will not display the menu functions. TV was working properly, turned off, upon turning back on, no sound or picture.
Any suggestions.
  • Sony Master
  • 8,457 Answers
U might get the tv working again,by unpluging it,replug an hour later let the tv reset it self.Not,Than the Tuner board,it the board u should looking into replacing.Not the power supply board is good,because u getting a solid power LED indicator light.
Posted on Apr 26, 2010
    Genius:
  • 1,175 Answers
Hi...
Look into getting the main power supply replaced
Check the web for someone near you
Posted on Apr 22, 2010
Panasonic TC-P42S30 plasma power light on black screen no sound?
Main digital board should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center
Mar 09, 2013 | Panasonic Viera Tc-p42s30 42" Plasma Tv -...
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
Sudden black screen during use, won't power down, won't power up sometimes.
If you haven't installed or not aware of any application installed recently on your laptop then--
your OS has been loaded with lots of unwanted or overloaded stuff;
1) First try to clean all junk files
2) Clean Cache
3) Free Up some space from your OS drive (most system it is C:\)
4) Uninstall unwanted programs
5) look into task-manager for his program usage
6) Check your Antivirus software
Apr 22, 2017 | Acer Aspire 5515-5187 Notebook
Had power cut when tv was on. Now comes on but black screen and then snowy screen then says not programmed. Can't get remote to work on side control buttons so can't get into menu to try and reset...
It is possible that when the Power supply failed the MEMORY WAS ERASED and so the programs that were memorised on the TV was lost.
Remove the power plug and push down all the controls to drain off residual voltage from the processor to allow it to reset. Now switch the TV after few hours and if there is no result or response from the remote the microporcessor / memory is faulty.
Get help, estimate and concur.
Aug 18, 2011 | Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Philips 28pt4523 tv - power on but no response to
check capacitors on power board if they are ok suspect is the tuner board
Mar 26, 2010 | Televison & Video
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
JVC AV-56WP30 56 black screen blue light on no response
make sure your front panel lock in your menu is not lock if is then unlock it cause it will lock everything on the tv in front and can't move anything
Jul 15, 2008 | JVC AV-56WP30 56" Rear Projection...
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
413 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
