YOU WILL NEED TO REPLACE THE CONDENSER COIL(HOT SIDE OR BACK OF THE UNIT) AND RECHARGE THE UNIT SAME AS IF THE UNIT HAD A REFRIGERANT LEAK.
COIL IS ABOUT $95
THE MANUFACTURER WILL PROVIDE YOU WITH A DIAGRAM OF THE CONECTIONS FROM THE CONTROL BOARD TO ALL THE COMPONENTS THE BOARD CONTROLLS. MIGHT HAVE TO INSIST ON THE REST OF THE DIAGRAM SPECS BUT THEY WIL PROVIDE THEM TO YOU 858-566-7473 BREEZAIRES NUMBER
DEPENDING ON AGE OFTHE WK IF IT IS AN R-134 UNIT(CHECK TAG ON BACK OF UNIT) AND IF ITS NOT RUSTED OUT IT SHOULD BE REPARABLE , BUT IF YOU WANT TO REPLACE I WOULD RECOMMEND A WKL MODEL OVER A WKE
IF YOUR UNIT IS A WKL IT SHOULD HAVE A SENTRI III CONTROLLER(BOARD) THAT HAS A LCD DISPLAY GREEN NUMBERS ON IT WITH BUTTONS(SET, WARMER, COLLER) IF SO THE ONLY OTION IS TO REPLACE THAT BOARD, A VERY SIMPLE PROCESS 10 TO 15 MINUTES MINIMU TOOLS, CONTACT BREEZAIRE AT 858-566-7473 THEY WILL SELL YOU A BOARD OR CONECT YOU WITH A DEALER TO BUY THE REPLACEMENT BOARD ARROUND $150 APROX
clean both coils(fins)and drain use non-detergent non additive oil(not motor car oil) for fan motor take cover off compressor relay and inspect wires(clean plugs and pins of oxide) you may need a hard start kit if it has a hard time starting
