Question about Maytag Neptune MAH5500B Front Load Washer
Error code upsidedown F followed by an e
Please help this is the 3rd time this has happened...repairman stumped
we have three teenagers...loads and loads of laundry to be done
  • washboard Jun 30, 2008
    I have the same problem today. I can place my machine on any setting, i.e. wash, spin, rinse, and I immediately get the upside down F and an E code. Help!
    President:
  • 1,314 Answers
Whats the model number on the washer and whats it doing and when get the model number off the serial plate and the serial number
Posted on Mar 23, 2008
  • Matthew Payton Jan 31, 2012
    Mine is a MAH6700AWW and I am getting the upside down F followed by an E.
SOURCE:
Error code f25 replaced inlet thermador
call a repairman we do not know what you have .
Mar 16, 2016 | Washing Machines
I'm getting error code FL when trying to start my washer. It will start to fill with water and then error. Please help! It seems like the door is locked.
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 23, 2011 | Maytag Neptune MAH5500B Front Load Washer
He3t error code FDL
Hi
Daniel
Nov 27, 2010 | Kenmore Front Load Washer
Power button beeps three times. Lock button works. Nothing else works.Technician diagnosed microcomputer control board. Replaced board control 8183258. Still dead!- he never called back.......help
Try to unplug power cord for 10 minutes and plug in. If you have manual on hand, follow instruction to find error code on your machine. Please tell problems before it went dead. Thanks.
Aug 10, 2010 | Whirlpool GHW9200L Front Load Washer
Stops Mid-Cycle: Error code is blinking ?H? then ?F?
FH, in mid cycle most likely your pump is blocked, hit drain/spin and see if water drains, if not clean pump
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
F35 Sud errors
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 10, 2009 | Kenmore Elite 45986 Front Load Washer
Error message of f dl on kenmore washer model he 4t
does your washer stop on spin cycle some time. your is 4/5 years old?. f dl means door lock system is bad but i don't think so. do you have other error code beside f dl if yes then i think your washer need new main control board.
May 24, 2009 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Error message F 2, just had repairman in who cleaned and replace drain hose... still showing same error and not draining water. Now what?
Other possible problems are:
  • bad electrical connections at the pump
  • check the drain pump filter for foreign objects
  • If these do not correct the problem, Whirlpool recommends replacing the pump
Hope this solves the problem for ya!
http://tclaundryrepair.com/
Feb 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code upsidedown f and e
ok you need to reply to the recall notices as that could be causing your promblems the code you are seeing is unusal high low temptures being sensed pop me an e mail at [email protected]
Mar 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
543 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
