Question about Jl Audio 12W7 Car Subwoofer
I cant get the wood off the speaker
Theres a piece of wood screwed to the top of the speaker and i cant take the screws of.
  • 4 Answers
Its because your fucken incapable of living.
Posted on Apr 23, 2010
How do I fix a squeak in a hardwood floor
squeeks in a hardwood floor most times are caused by the hardwood separating from the underlayment (board) and hence it piviots on a nail and you got a squeak !! , there are a few ways to fix this "
if the squeak is located in a spot that is accessible from under the floor , see if you can determine what hardwood and underlayment thickness is , look around behind a floor casement or around a doorway trim with flashlight , find a wood screw that is 1/8 less than this number (two added together ) also locate a drill that is just size of screw shaft you found , drill hole from under the floor (underlayment) just deep enough to penetrate the underlayment (3/4 inch or so) use tape on bit as a gauge , don't drill into hard wood then drive wood screw into hole , the idea is that screw will pull hardwood down to underlayment , screw cant grip underlayment due to hole so this is piviot point . a shot of wood glue on screw threads helps it from coming out too !!
now if space under squeak isn't accessible this is a bit harder but not impossible to do , there are a few special items to get first , one is a glue injector needle !! this typically is used making wood furniture but I have seen a meat basting syringe used in a pinch too, locate the spot close to squeak from top , using a small drill dril down at seam (not in middle of board) just deep enough to hardwood Not underlayment , load up your syringe with wood glue and force it down into hole with needle takes some force to do this , wipe off spilled glue and set a heavy object on this spot for 24 hrs object can be a lg pile of books or I use cement blocks (4) set on a piece of butcher paper (not cardboard) after 24 hr remove blocks and ck for squeak if none use hard setting tinted wood filler to plug hole you made and top off with a dot of varnish to seal it when dry and flat if you still detect the squeak then move over a board or two and repeat process till squeak is gone
Jan 03, 2017 | Vacuums
My 95 buick le sabre needs new front speakers but i cant figure out how to get off the front plastic piece
the door speakers?
there is one screw near the handle to open door, there is a screw on the outer edge of the door panel, you pop off the switch cluster and there is 2 screws in there, the door panel will have clips that hold it on, gently pull to pop them loose, the speaker is at bottom right, if you have concert sound II there is also a tweeter above the speaker
Sep 18, 2011 | 1995 Buick LeSabre
HOW DO YOU REMOVE THE WOODEN CONSOLE COVER THAT
Remove roll top center box by removing screws. Remove all screw under flat areas and at end of wood. Pull up on shifter plastic surround. Lift wood off , switches will come with it and unplug from there connectors.
Jun 08, 2010 | 1990 Mercedes-Benz Mercedes Benz Sl Class
How to adhear light fixtures that are all connected to a piece of wood to the wall. Tried screws and they crack the wood..
Drill pilot holes for the screws first and the wood won't crack. The holes should be slightly smaller than the screw.
Apr 27, 2010 | Home
Water leaking from machine,trying to lift top of washer looks like hinges in back but cant seem to open
usualy there are hinges in the back and spring clips in the front, lift the front top usiing a bit of force( pry it with a thin piece of wood). make sure all the screws are off around the top , and pull out the lint fillter , there may be 2 more screws there
Jun 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Handle has pulled away from the door. How can I access the screws
Realized the top chrome part split into 2 pieces and then was able to remove the wood like strip in the chrome strip. Popped the top chrome anchor, reattached the handle bracket as the screw holes were not stripped, put the wood like strip back in place and slid the top chrome anchor back in place.
Feb 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
93 BUICK LESABRE CUSTOM dashboard dissassembly
turn air vents to one side once all the way pull on the part sticking out the most they all come out like that.There will be a screw on the top inside of the vent remove these from each vent.On the bottom were your ac control panel is there is plastic wood grain piece that goes across the dash.Get a flat head screwdriver stick in top of wood grain pry out and work your way down.theres also a small piece on the driver side same senerio.theres a couple screws above the gauges also two in top on inside glove box.
Jan 27, 2009 | 1993 Buick LeSabre
Screen removal
Screen Removal
There are two types of screens used on this chassis.
Model 1 - with one piece frame around screen.
1. Remove the front grill cloth assembly and remove four
(4) screws along the bottom of the screen frame.
2. Pull out slightly on the bottom of the screen frame and lift
up and out on the top of the screen frame (and screen) to
remove.
Model 2 - with wood piece securing top of screen.
1. Remove the screw access cover plug from each side (near
top) of the TV and remove one screw from each side.
2. Pull up on the wooden strip and remove.
3. The screen can now be lifted out of the tracks and
removed.
Jan 21, 2008 | Televison & Video
Speakers
First you figure out the air space needed for the sub. then figure out how much room you want to take up in the vehicle. If your subs came with the manual, It can then tell you the rest.
Nov 18, 2007 | Car Audio & Video
Jl Audio 12W7 Car Subwoofer Logo
43 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
