Question about LG Washing Machines
IE code keeps coming on, the water wont drain - Trom LG front load washer
  • 6,784 Answers
HI. This code is in reference to your inlet valve assembly. There may be an obstruction, or the actual inlet assembly may be malfunctioning. Use the procedure below to help guide you through the necessary inspection.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are receiving proper water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
Posted on Apr 22, 2010
IE keeps coming up on our front load washer
On most washers, IE error means that the washer is not seeing proper hot and/or cold water inputs. Check the hoses for kinks. Ensure the water valves are fully open. If these are not faulty, turn off the water, remove the hoses at the back of the washer, and check the input filter screens for clogging. This is a common problem.
Feb 26, 2015 | LG WM2010CW 3.5 cu. ft. Front Load Washer
LG trom wASHER wm20160W WONT DRAIN
Start by getting to the drain on the pump there should be a hose hooked to the pump and there may be a filter that u can clean out. Check the pipe and make sure it is clear and also check the discharge hose to be sure it is clear as well. By the way do u hear the pump come on or try to. If lines are clear and the pump is running then you most likely have a bad pump,
Apr 20, 2014 | LG WM1814CW Front Load Washer
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Aug 04, 2008 | LG WM-2277HW Front Load Washer
LG TROM STEAM WASHER-WM2487 HRM
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap and softner.
Jul 31, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG Trom wm2077gw OE error code and won't come off and empty macine I washed a comforter and it shredded part of it and is stuck on OE what does this mean and how do I fix it. Thanks
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
May 20, 2008 | LG WD-14124RD Front Load Washer / Dryer
Washer
Anne,
The lint filter is clogged preventing the pump from draining all the water from the tub. Open the little panel on the front lower left of the machine, unscrew the lint filter and clean it. Make sure you drain the trapped water first (before you remove the filter), by pulling out the little rubber hose (you'll see it) and removing the plug from the end.
BW
Apr 02, 2008 | LG WM-2277HW Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
572 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
