Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
When plugging into the air line, the driver extends and will not retract.
  • 2,176 Answers
Could be the trigger assembly has a stuck o ring or the firing valve is sticking, I would look at the trigger assembly first.
Posted on Apr 25, 2010
How to put oil and bleed it in a FM Quality
place the body of the pump horizontal on the bench. make sure that the ram is in the fully retracted position. Remove the air bleed screw at the end and use a small funnel to run oil into the body of the pump. When full pump the unit to extend the ram. When it is fully extended then release the hold valve and retract the ram. do this a few times until you see the ram extend smoothly with each pump. Check that the oil is just short of full and replace the vent plug
Oct 08, 2014 | Cars & Trucks
How do I replace a broken line on a retractable clothesline?
You will have to extend it fully, then take the housing apart to get to the anchor points for the line. Once there you can see how it mounts. Then replace the line with same length replacement line.
Sep 20, 2014 | Cameras
Brad nailer not firing properly
need to rebuild. the kits are about $15
Jan 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Log splitter how to flush hydraulic system
removing hydraulic oil from the system
  • fully extend the cylinder. and shutdown.
  • remove the one end of the hose that is from the rod end of the clylinder.
  • two ways you can go here. either: detach the one end of the hose that is attached to directional control valve and leads to the cap end of the cylinder and place the end in a pale then retract the cylinder by physically forcing the rod back in and all the oil will drain out of the cap end into the pale and the rod end will fill with air.
  • or u could hold the directional valve in the position to let the oil flow back to tank while physically forcing the rod back in. the oil in the cap end will drain to tank and rod end will fill with air.
  • drain the tank of oil.
  • if you wanted to be extra thurough remove the remaining lines and drain the oil out of them.
  • reattach all lines.
  • replace oil filters/strainers. should be one on the return line going to tank. and one on the suction line before the pump. But there may not be a second filter.
  • fill tank with new oil.
  • extend the cylinder using the pump. allowing the air to bleed off the rod side. may chatter at bit while extending. if excessive chatter remove line end to allow the air in the rod side to bleed to atmosphere and continue till fully extended.
  • reattach line. probably a good idea to run a couple cycles.
  • and repeat the entire process for a thurogh flushing.
  • ! note: dont be dissconnecting lines with pressure in them or while the system is running.
  • ! note: be sure to have enough oil in the tank so the pump is not sucking air. this will eventually cause unrepairable damage to pump if sucking air for too long.
  • i just wrote this off the top of my head and ive only worked on industrial hyraulic systems and never on a log splitter before so just keep that in mind. hope it helps
Dec 04, 2009 | Plumbing
Seatbelt is retracted and will not extend.
the safety pre tensioner has gone off, was it ever in a crash? what ever the case it needs a seat belt,
Nov 18, 2009 | 2001 Kia Sportage
Sony Cyber Shot lens extends and retracts, can't take photo
My solution for the M340
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Sep 13, 2009 | Kodak EASYSHARE M340 Digital Camera
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
108 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
