Question about JVC Televison & Video
Hey i just replaced the lamp in my jvc 61' tv and needed to know how to reset the time
  • atelier mj
    atelier mj May 11, 2010
    NEED MODEL # FOR HELP YOU
    Novelist:
  • 132 Answers
JVC Lamp Reset
Go to Clock-Timer Set-up in users menu. Select reset lamp.
easyab
Posted on Apr 22, 2010
    President:
  • JVC Master
  • 1,779 Answers
Scroll down the menu till you see "Lamp Reset " press Enter and your done..
TV blue light comes on, then the red light blinks two times, on the 3rd blink, it goes into rapid blinking. I replaced the lamp and it worked for a week, but then the same issue. I put the old lamp back...
some units require a lamp counter reset.the ballast usually starts at extreme output and at certain hour interval the ballast would start to decrease voltage as the bulb ages.to reset on some models can be reset using the remote
Aug 12, 2013 | JVC HD-61Z786 61" Rear Projection HDTV
HOW DO I REPLACE THE LAMP
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
May 18, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
I have a jvc tv model HD61z575 It just went out and the led lights are blinking fast at the same time I checked the lamp it looks fine any suggestions
Looks can be deceiving. The lamp is gone. I've had the same tv since 2006. Mine just blew out again. Replace the lamp and all will be well.
Jan 02, 2011 | JVC HD-61Z575 61" Rear Projection...
Have a jvc projection tv picture is to dark how can i correct this
How long is ur tv projection lamp been inside this tv.If the tv projection lamp been inside the tv like 1 1/2 or 2 years and watches tv everyday like 4 or 5 hours daily.The tv projection lamp life are ending.Replacement of the tv projection lamp,will solved this problems.
Dec 28, 2010 | JVC HD-61Z786 61" Rear Projection HDTV
My jvc 56' flat screen is showing a message in blue to replace lamp but there still is a good picture?
Well, the message is trigger by the passing of time. The TV simply counts the hours the TV has been on, then when the counter hits the designated amount... the message starts to appear. Best thing to do is order a lamp and have it on hand. You can go into the TV menu and reset the lamp timer for now, just to get the message out of sight. When the lamp does fail, change the lamp and reset the timer again. I hope this was of some assistance, best wishes.
Apr 12, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
AFTER REPLACING LAMP THE LAMP LIGHT IS STILL FLASHING
Look in the manual under "resetting the lamp timer"
This must be done with most any replacement
Browse to:
http://www.retrevo.com/r/391dj496/48/Lamp+Timer+Reset#q=JVC+HD-61G787
On that page is the (lower) is the exact procedure on resetting the lamp timer. You can also down the entire manual in PDF format.
Cheers
Jan 15, 2010 | JVC HD-61G787 61" Television
Changed lamp in 61 inch jvc dlp and still can't get tv to turn on
Ballast board is what turns Lamp on and CK your Fans if Lamp Fan is defective TV willnot come on.
Dec 11, 2009 | JVC HD-61Z575 61" Rear Projection...
Have lamp message in JVC HD-52Z585 to replace lamp #TS-CL110U.
I would, it's cheaper than replacing the whole TV and you can do it yourself so no labor bill. The new lamp usually comes with directions and in my experience the JVC lamps are outlasting some of the other ones.
Sep 10, 2009 | JVC HD-61Z786 61" Rear Projection HDTV
Replacing the lamp
Should be a pretty simple matter. There is a door on the back left side.
Did you buy a lamp or a lamp and housing?
DO NOT TOUCH THE LAMP BARE HANDED!!!
Dec 11, 2008 | JVC HD-61Z786 61" Rear Projection HDTV
Televison & Video Logo
261 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
