Question about Sylvania DVC840F
No video; audio OK. Hooking up to new (used) TV.
No video; audio OK. Hooking up to new (used) TV. Ideas?
Player may have damage from liquid spill.
Is is best to use coax or 3 plug cable (red/white/yellow) to TV?
Thanks,
Judy
    Genius:
  • 1,175 Answers
Hi... The 3 plug cable is better as long as you match all the colors at both ends.
If there is left over stuff on the laser lens , it wont read the disk
Posted on Apr 22, 2010
Why did left speaker stop working?
If the speaker is not defective, a common problem with the AWR1CG and P models is liquid damaged circuitry. Where openings in the top case appear over the circuitry, spilled liquid drips down and may damage, or over time badly corrode, the circuit board traces, small through-connections, and/or electronic components. This is not a repair an untrained/experienced person should attempt. We service many of these liquid damaged units with good success rate. CET Services, 117 Windsor Ave, Hurley, WI 54534 // don.miller60@outlook.com.
Dec 31, 2015 | Bose Awrc1g Wave Radio Cd Player Only -...
I hooked up my wii on av1 with a component cable with audio on audio 1 and i have sound but no picture.
If I am reading this right, you are only hooking up one cable for audio. There is another cable needed for video. This jack is normally color coded yellow and labeled video out/in. You can use your audio cable to try this and then you will picture but no audio.
Feb 16, 2014 | Yamaha RXV371
Excellent picture but no sound
This problem has 3 possibilities, that your tv audio output is already damage or the cables that connecting to your tv and digital reciever is loosed or damage and may be your digital reciever sound pre amplifier is damage. Let's start to your tv, try to use a dvd player or cd player and connect it directly to your tv audio video input, or you can remove the connection from the digital receiver and use a small piece of wire then connect it to your tv antenna input and set your tv mode to aerial tv.If the tv produces sounds your tv is ok. To wire connection, first try to check all the cables that connecting to your tv and digital receiver specially the input, output connection,If wire is ok. Then the digital receiver has the problem try to contact service provider and ask if your digital receiver has a warranty.
Jul 16, 2011 | Samsung 50 in. TV
I was hooking up my sisters surround reciever for her and used an optical cable to the reciever from the TV. Her TV gets signal from the cable box via coax and uses HDMI from DVD player. I am stumped that...
srry but the tv is not capable of sending hdmi audio through its outputs the dvd player audio must be run through rca red and white or black if you have digital audio out to the back of the receiver on its own channel
Jan 11, 2011 | Audio Players & Recorders
I spilled liquid in the receiver, now it flashes on then shuts down. Is there a fuse I can replace or is it shot?
There are fuses, but they are OK. You've damaged the receiver, it's starting to fire up and then see's a short circuit so it's shutting down to protect itself.It needs shop service unless your in electronics.
Apr 13, 2010 | Audio Players & Recorders
I have audio but no video whyen a disc is
Turn off all devices in the video chain, INCLUDING your Xbox.
Unplug and re-plug ALL connectors, making certain that they all go in all the way.
Turn on everything.
If that does not fix it, then something is busted.
Remove anything between the TV and the Xbox and try it again.
If that does not work, either the TV or the Xbox is busted.
Try hooking up a DVD player to the SAME EXACT TV input.
If that works, your Xbox is busted, go buy a new one.
If that fails, go buy a new TV or try using another input on that TV.
Feb 07, 2010 | Microsoft Xbox 360 Console
I'm trying to hook up using 2 little rca speakers, for L/R i've set the reciver to 2 speaker setup and for some reason i can't get sound from my speakers. any ideas? I've got HDMI from a Samsung DVD player...
If the amplifier supplies a different resistance rating (ohms) than the speakers draw, it might automatically shut down the amplifier to protect from damage. Make sure the Teac output matches the speakers required input. Hooking up speakers that draw 8 ohms to an amp that supplies 2 ohms can cause amplifier damage.
Sep 28, 2009 | Teac DC-D2800 Shelf System
DVD Player not working
Go to menu. Select inputs. Assign input 1(or whatever input you connectedthe dvd to) as DVD. Then exit menu. Press the input key, scroll over to DVD. I reccomend using a component cable with a digital audio cable, if you do not have a DVD player that has an HDMI connection. You will find that a blu-ray player will be much more satisfying for the television you have. Basically by hooking up that old dvd player to that tv, is the same as hooking an 8-track to a $2,000.00 stereo. It will work, but the quality is going to suffer! Good luck, and believe me. It is worth the extra money to get a blu-ray player. It will play all your old dvd's and blu-rays. That way you are getting the full potential of your set.
Dec 22, 2008 | Mitsubishi WD-60735 Projection Television
Hooking up DVD player to proscan TV. Video is coming thru but there is no sound.A digital cable box from comcast is in the mix. I can usually figure things out but I am stumped on this one. Any ideas?
Hi,if you have video and no sound you have hooked up the dvd with component cables but you still need phono cables for sound,run these from the dvd audio output to tv audio in,if you have a amp for sound come from dvd out to dvd in on your amp.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Open Questions:
Televison & Video Logo
104 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
