Question about RTO Atwood DSI-RV Water Heater-6 Gallon
How hot are the 12 volt house lights suppose to get? I'm plugged in to a 20amp. I have a 2000 Fleetwood bounder
  • 2,100 Answers
They get hot, just like a regular bulb. It will burn your fingers. Ever see a car's brake lights that have melted through the lens? Hope this helps.
Posted on Apr 22, 2010
Testimonial: "I thought that but wasn't sure thanks"
1999 fleetwood prowler 25 5b
You need to visit a local dealer...any RV dealer. They should provide a general walk through as a courtesy. Pay them for a maintenance inspection and they can provide a detailed explanation of their work. After that you might be able to troubleshoot/repair simple problems yourself.
Feb 15, 2014 | Water Heaters
One of my poer sources is out. How can I fix it??
I am not familiar with your unit but I believe it has 3 12 Kw heaters. I would guess one of them has failed or the relay powering it has.
Feb 04, 2014 | Stiebel Eltron Tempra 36 Whole House...
Need to add electric heating element and thermastate to g6a-6e gas water heater
I don't know how you can drill into aluminum tank and install element.
That seems a good way to ruin the heater.
Why not just buy small 'under counter' 1500 watt electric water heater at local box store and install in-line before the water reaches atwood gas heater.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Otherwise I do not have a solution.
Don't blow yourself up by messing with gas appliance.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 16, 2013 | Water Heaters
I have a G6A-3E heater. didn't work untill I cleaned the terminals on the t,stat It works but shuts off befor the water is hot!
Take a multimeter or 12 volt test light and probe terminals on Therm & ECO for 12 VDC power while running. When it shuts down and wateris not hot, test for voltage again at those terminals, If you have 12 volts to side of therm that goes to ECO beside it, then therm is ok, but then check opposite side of ECO as well. If power on one side of ECO, but not the other, the ECO is faulty. Simply walk across with probe testing for voltage when you find no power at one terminal but not the other, it's faulty, replace it.
Feb 16, 2013 | RTO Atwood Water Heater - 6 Gal LP
!990 Bounder By Fleetwood Water Heater is not lighting the propane
Check the gas line orifice for a spider web. Its possible the gas is not able to get past the web.
Nov 30, 2012 | Atwood Mobile Products Llc Water Heaters...
I have a 1997 Fleetwood Bounder with an Atwood G6A-8E water heater. My pressure relief valve was leaking heavily, and I think it shorted something out, because now my electric igniter will not light the...
Have you checked your fuses? there should be a removable cover to pull off there will be a fuse in side that powers the self ignite..can you take a pic of the panel and post it or send it to my email?
Nov 30, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
The direct ignition switch will not light the burner, We have replaced the switch, but it still does not light.
Have you checked for 12 volts DC getting to spark module ? If it's just the 2 wires going to spark module, Red and green, check for 12 volts at the red wire.
If it has the 9 wires on 2 connectors, check for 12 volts at Brown and Orange. If no 12 volts there, then you'll have to go back to switch and check there for 12 volts in and out when switch in on position. Let me know what you find.
Sep 02, 2009 | RTO Atwood Water Heater - 6 Gal LP
My Atwood Hot Water Heater leaks when I turn the pump on.
Where is it coming from? It would make sense to have a plug in the conwe of the tank. Need you to clarify what it is lthat is leajing.
Jun 12, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
150 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
