Question about Denon AVR-2106 Receiver
What is the baud rate, data and parity of the AVR 2106?
3 Suggested Answers
  • 11 Answers
SOURCE: My Denon AVR 2106 gives sound out periodically in all modes
So you have no sound on any Inputs?  This makes a difference, if it works on some inputs but not others.  For a factory reset - turn the unit off by the ON/OFF button (not the standby button) hold in the SPEAkER A & B buttons at the smae time, while pressing them turn the system on by the ON/OFF button, wait about 3 seconds and the unit should reset everything.
Posted on Apr 05, 2009
smarthome2
  • 1114 Answers
SOURCE: Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Posted on Jul 01, 2009
I have symbol ls9100 400bc it read barcode but does not display out put
Seems like you need to setup the communications protocol. You need to setup the type of communication that the device you are connected too if serial port then RS232 plus baud rate data bits parity etc.
Nov 10, 2014 | Zebra LS9100 PEARL WHITE HOLDER ROHS
How do you program a scanner to a samsung till?
This is a big job. It is not normally performed by an end user. You need to set the port device, baud rate, parity, stop bits, word length on the register. On the scanner, set the baud rate, parity, stop bits, word length, prefix/ suffix, code types. Don't forget to check that you have the correct pinouts on the RS232 cable as some models require a specialist one. If none of that makes sense to you, it is best to take them to a dealer to have them set up.
For those members who have asked for a samsung SER6540II manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Samsung_SER-6500II_and_6540II_operating_manual.html
Jul 05, 2014 | Casio Parts Cash Register PC Desktop
I have an Epson TM88II and it only prints question marks. How can I solve this
??? Assuming using serial port ???
Question marks are substituted for bad data.
Normal reason for this is incorrect Baud rate.
Test:
Power on printer while holding feed button.
Current settings including baud rate will be printed.
Press feed a second time to complete the test print.
Set port to setting specified by printout.
e.g.
(at command line)
mode com1:9600,N,8,1
mode port : baud , parity , data bits , stop bits
I hope this helps
Mar 12, 2010 | Epson Office Equipment & Supplies
Need to connect to the console port what are the settings
This all depends on what model of firewall you have.
But the settings are most likly
Baud Rate: 9600
Data: 8 bit
Parity: none
Stop: 1 bit
Flow control: none
You may need to play with the Baud Rate
Oct 20, 2009 | Computers & Internet
Running two Zebra's through Easylabel Platinum
When connecting Easylabel to a Zebra through the RS232 port, it's very important that the serial settings match between Easylabel and the printer. Easylabel defaults to 9600 baud, 8 data bits, none parity. The Zebra defaults to 9600 baud, 7 data bits, and even parity. This mismatch causes the data light to flash but no print.
Change the printer setting to 8 data bits and none for parity and the baud rate can be whatever but make sure they match from Easylabel to the printer.
Hope that helps !
Sep 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Jun 28, 2009 | Denon AVR-2106 Receiver
4800 baud rate communication in vb
You have to change it on both side!
If you are communicating your PC with a serial device, BOTH must have the same speed (serial device: 4800, pc: 4800)
Have you done it?
Most devices DEFAULT settings are 9600 baud rate, N, stopbit1.
But you can change it depending on the device...
Jan 03, 2009 | Computers & Internet
Jan 01, 2009 | Denon AVR-2106 Receiver
Prints gibberish
print a selftest:
turn printer off then hold down the feed button, turn printer on and release feed button whenever it prints something.
pls reply back with info on printout, such as baud rate, parity and other info specially interface, thanks
May 13, 2008 | Epson TM-T88III Thermal Printer
Verifone printer 900 - How to find the current settings
There are 4 DIP switches located underneath the paper holder (bottom).
SWITCH1: ON => Even parity, OFF => Odd parity.
SWITCH2: ON => 8bit word (no parity), OFF => 7bit word.
SWITCH3-SWITCH4: ON-ON => 1200baud,
ON-OFF => 2400baud,
OFF-ON => 4800baud,
OFF-OFF => 9600baud.
Good luck...
__________
Samir.
Nov 14, 2007 | VeriFone 900 Matrix Printer
Denon AVR-2106 Receiver Logo
42 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
