Question about Bernina Sewing Machines
Bernina 900 ''Electronic Power'' foot control needs repair
Little carbon contacts are broken inside - simple fix if I can find those little carbon contacts. Or where can i buy a replacement foot control?
  • 22 Answers
You will need to go a bernina dealer to by those pins the part number is 325 355 031 and each pin cost around $4.00 each
Posted on May 03, 2010
  • Rod Faint
    Rod Faint Dec 17, 2013
    This was a helpful solution. Hopefully I can purchase the pins required as it is unlikely that a replacement foot control is available.
My Bernina "Record" of 1972 suddenly stitches away without foot pedal command, infact same with pedal unplugged Only way to stop is cut AC power
Something with in your machine seems to be shorting out. Since it is many years old I suspect you have wires that the insuation is rotten and making a short. I have seen this before. Should get it repaired if it's worth it. You could be shocked or hurt.
Oct 21, 2016 | Bernina Sewing Machines
I have a Bernina Sport and when I press the foot pedal only intermittently does power go to the machine. How do I correct this?
It could very well be the carbon brush. It is generally a piece of soft carbon (like pencil lead) with a spring on the end which applies pressure. When the carbon gets worn down, it does not make consistent contact. Depends on your machine model. I've replaced carbon brushes on the motor of an 830 Record, but I had to replace something in the foot control. Do not despair. The replacements can be found for ~ $12-15. Available multiple places. Just be sure they will fit your machine.
2 Bernina Carbon Brushes for All New Style Machines eBay
Oct 11, 2016 | Bernina Sewing Machines
Bernina machine starts sewing anfmten stops or doesn't start at all.
Be sure that you regularly clean and oil your Bernina. If not oiled regularly, the old oil turns to varnish and actually freezes the parts. Some people believe something is wrong with the motor or foot control, when really it just needs some TLC to keep it running smoothly.
May be one of several issues--depends on the model Bernina. Could be a problem with the foot control. I had to replace a carbon brush in the foot control of my 930. (A new foot control could cost over $160!)
Repair Bernina Type 290 Foot Control Pedal
http://sewing.patternreview.com/SewingDiscussions/topic/92721
https://tv-sewingcenter.com/bernina/bernina-830-fire-hazard
Sewing Foot Control Replacement
Or some machines (mostly older models, ie 830 Records) have carbon brushes on the motor that wear with age. Once they've worn down, they no longer make constant contact giving you the "intermittent" issue. I've replaced carbon brushes on some older Berninas--usually found somewhere around the motor (look for a screw or knob on the motor). You can buy replacements a lot of places. I've purchased them on eBay.
Sewng machine motor housing
How to fix replace Bernina Record 830 sewing machine motor capacitor...
Where are the carbon brushes located on Bernina sewing machine located It...
Carbon Brush Bernina 324250080 (make sure it will fit your model)
http://artisanssquare.com/sg/index.php?topic=3040.30;wap2
Oct 01, 2016 | Bernina Sewing Machines
How do i fix bernina 130 foot pedal?
Likely you cannot repair it personally you will have to find a dealer to order a new electronic controller and cord to be installed inside the foot control.
Aug 02, 2014 | Bernina Sewing Machines
How to repair globe overlocker M23A-5 foot control
If there are broken parts inside the foot control the entire control probably should be replaced.
Dec 17, 2013 | Sewing Machines
My wonderful Bernina 1130 has served me loyally since purchase in 1988, often being used every day when I worked as a dressmaker. In recent years full-time work keeps me from sewing. My faithful Bernina...
Contact an authorized Bernina dealer/repair center. The service technician can often tell what board needs to be worked on, take it out and send to Bernina. I just had to have work done on my 1130 and that is what was done. If that does not work, look up the number and call Bernina USA directly so they can direct you. While it's true that some parts are no longer obtainable, the machine boards can be serviced by Bernina USA. It's worth fixing.
Sep 29, 2010 | Bernina Virtuosa 160
I have a Bernina 830, bought in 1978. When I depress the foot pedal, nothing happens. Power is on. Do I need a new pedal?
I've just fixed this problem by replacingthe main capacitor in the foot pedal. I have a Bernina 830. I needed a soldering iron, and I had to buy the right capacitor, but it fixed this exact problem. Btw, a few months ago this problem initially appeared (on my machine) as an issue where the speed was either zero, or full speed). After a white it wouldn't work at all.
Jul 23, 2010 | Bernina Sewing Machines
BerninaMatic 910 Electronic machine. The foot control has broken
Bernina foot controls cost a fortune, have a look on ebay you find someone selling spares, other than that it will mean going to a Bernina dealer
Nov 03, 2009 | Bernina Sewing Machines
L board
Hi Tonette....I'm afraid that it is impossible for me to diagnose your current issue over the internet with any degree of confidence. However, I can educate you on typical norms for your specific situation and machine. Typical "tune-ups", also advertised as "clean, oil & adjust", range from $19.95 to $49.95. Of course, the 19.95 special is designed to get you in the door. Bernina Bobbin Cases do generally run on the 'higher' side of things, between 30 & 60 dollars. However, regardless of what Class any given Bernina is in, the electronic components all originate from the same manufacturers with similar benchmarks regardless of class. Replacement of any given electronic component, once accessed, is as simple as plug and play, with no adjustment or fine tuning required. As far as cutting your losses, in my opinion, you had already lost when you paid the 170.00
Oct 08, 2006 | Bernina Virtuosa 160
Sewing Machines Logo
501 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
