Question about Poulan Pro " Pro" Self Propelled Mower
Will not start
The lawnmower was running fine. The self propelled wheels stopped turning. Then he turned it off. When he went to start it again, it would not start. It is also very difficult to pull the cord.
It is about to rain and the lawn is half done. Please respond quickly.
Thank you.
  • 110 Answers
Completly disconect self propled belt or gear should be able to mow til you fiigure out whats up with self pro some thing is jamming selfpro ps if you have to turn it upsidedown kill switch on
Posted on Apr 22, 2010
Lawnmower won't start.
blades blocked?
Apr 25, 2017 | Garden
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
Why does my torolawnmower take off when i start it?
I have a riding toro lawn mower that cut off on me and wouldn.t start back, what could be my problem? The crak wheel trys to turn but it won,t turn over
Dec 11, 2012 | Toro Lawnmower Lawn Mower SP Drive Belt...
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 self propelled lawnmower stopped self propelling! T
Removed all the debris that had wound around the front wheels and it works again. Thanks for the help.
Sep 03, 2009 | Toro Lawn Mower With Toro Power Tools
Poulan Pro " Pro" Self Propelled Mower Logo
371 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
