Question about Samsung SyncMaster 913N 19" LCD Monitor
Y have one problem my monitor. The transistor q2 to Screen PCB is damage.Please, how type is this transistor? Best regards!
  • 11,361 Answers
You can download service manuals here: http://elektrotanya.com/?q=showresult&megnev=SAMSUNG&megnev2=913N&kategoria=&kat2=all
2 downloads per day.
Please send me pictures so I can look at them also.
budmrtn@aol.com
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 22, 2010
Curve BOTH side screen AND ZOOM
You should direct your attention to the East/West correction
circuit. If the line output transistor was replaced due to it having
gone short circuit, damage to this circuitry is likely. Also check the horizontal driver transformer for dry joints, a fault here will cause random failure of the line output transistor
Best regards Vintie
Oct 27, 2013 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Qsc mx 700 keeps blowing fuses after replacing all transistors with replacement parts not original
Have you replaced the IC , Q2 and Q2?
• Check the Differential Inputs ( IC1 ) and sorrounding components
• Check the Driver Stages
additional guides or suggestions:
Cross wired speakers and blown power transistor.
Beware also of counterfeit Power Transistors
Aug 05, 2012 | Audio Players & Recorders
I brought my benq t701 to a repair shop to due blackout screen. But due to lack of parts, it was not repaired but all 6 transistors were removed from the PCB. Please show me where these transistors were...
go to esservice.com and get the manual from there will be easier as the transistors are directional i believe they are 2sc5707s from memory but you will need to check the transformers and the 2 filter caps on either side of them as if they are faulty will blow transistors.
Dec 30, 2009 | BenQ T701 TFT 17" LCD Monitor
My moniter screen has turned to blue screen and i am not able to
On your CRT back PCB thers three transistor on for red green and blue its possible that your blue transister is faulty. Try moving your cable see if the colour changes it can also be a faulty 15pin plug
Have a nice day
Dec 24, 2008 | HP Compaq FS7600 17" CRT Monitor
NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
Horizontal and vertical adjustments
Check components related with pots thats adding command ic to pots.If they are ok then change command ic with new one.Before this you can check horizantal hold transistor that is placed on hitsink of eht.small in size and check two small transistor placed near it on pcb.Hope this solution works .If not then i am here
Mar 10, 2008 | LG Studioworks 45 14" CRT Monitor
Monitor not Display
Hi Rey,
Hope this helps you like what I did to resolve this kinda problem. If you can manage to open the chassis/cover check first if the HOT (horizontal output transistor) is good, if good check the SMPS (switching mode power supply) primary and secondary side if there are short filter capacitors, diodes, transistors and open resistors. Major faults to consider is by checking the load of SMPS, control circuit, driver circuit, feedback ckt.
Please let somebody to assist you (a certified technician) how to open the chassis safely due to electric shock. Please be guided accordingly.
Best regards,
Rosener Guyano
Jan 30, 2008 | MPC Computers AOC 7F 17" CRT Monitor
AOC 5En monitor
replace new moitor....
Nov 13, 2007 | AOC CT720G 17" CRT Monitor
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
Samsung SyncMaster 913N 19" LCD Monitor Logo
88 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
