Question about GE Advantium SCA1001SS Convection / Microwave Oven
Everything works, but it has stopped heating.
Within the last couple of days, we have not been able to heat anything up. Other that that, is works fine. It goes on and sounds like it always did, the turntable works, the light goes on ext.
  • 6,784 Answers
HI. Your symptoms are a strong indication of Magnetron failure. This is the principal heating device, that is used to produce microwaves that , essentially, excite the water molecules in the food, thus, producing the heating effect. When this device fails, generally, the unit will run, but not heat. This device is very fragile, and can injure you if you are not qualified to handle this type of component. There is a High Voltage Capacitor, that is used to help provide the necessary current for optimal Magnetron operation. This capacitor must be discharged correctly. If not, you could risk serious injury, during the repair, if it is accidental touched.
The Magnetron is linked to a cut-off fuse. If the magnetron becomes unstable, this fuse will shut the device down. It is standard procedure to have this fuse test for continuity. If the fuse has blown, this will be the culprit. Replace the fuse. Now, if the fuse continues to show continuity, this will confirm that the Magnetron has failed. I would advise to inspect the Capacitor, and HV diode for visible burn marks, or swollen top(Cap).
Access can be ac hived to these parts by removing the outside cabinet screws. Once the screws are removed, the cover can be removed, as well. Once the cover is removed, the internal components will be exposed for testing, and visual inspections.
WARNING: IF YOU ARE NOT A QUALIFIED SERVICE TECH, THIS WILL NOT BE A NOVICE DO IT YOURSELF JOB. MICROWAVES ARE VERY DANGEROUS, AND CAN CAUSE SERIOUS INJURY. I RECOMMEND TO CALL FOR SERVICE, IF YOU ARE UNCOMFORTABLE WITH HANDLING THE CAPACITOR, OR MAGNETRON.
Posted on Apr 22, 2010
Magic chef microwave just stopped heating, can you tell where the fuse is so i can check it, and i am open for any suggestions. model # hdm111ow
Sounds like the magnetron has failed, if it were the power supply or capacitor or fuse, it would have failed to heat straight away, not faded out. Probably more economic to replace the machine.
Feb 22, 2017 | Magic Chef Microwave Ovens
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
Hamilton beach microwave stopped working suddenly. attempted to heat a breakfast sandwich...and it stopped working after heating a food item moments before. I purchased the microwave within the previous...
Typically, you have the first 30 days to exchange a new purchase. I would pursue that avenue. If you bought it online, it's probably freight related. Try to file a claim..
Oct 31, 2013 | Hamilton Beach 1.1 Cu. Ft. 1000-Watts...
Swan SM2050 microwave - everything works (light, turntable, LCD display) except it only sometimes heats and other times starts to heat but will then stop heating whilst everything else continues to...
you not going to like me now!!!! in two words,,,,,dump it,,,, your microwave is well past its best,,to fix it will cost more than its worth, and to be honest there getting cheaper by the day now?
Nov 28, 2010 | Microwave Ovens
Microwave not heating anything? everything else work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgshg
Jul 28, 2010 | LG LMH1517 1000 Watts Convection /...
Microwave doesnot heat anything
6 years is a good run for a microwave to keep working
as it is basically a high frequency radio transmitter, take it in for a proper diagnosis and a quote
mostly after 6 years there may be a shortage of parts available for repair so keep in mind that it may be cheaper to junk it and get a later model
Mar 08, 2017 | LG Galaxy Countertop Microwave Oven
Our kenmore microwave stop heating.. Everything works well but it just stop heating last night after l cleaned it.. did I do anything to it??
heatman101
78g
May 15, 2010 | Kenmore 63792 Microwave Oven
Ge jvm1870 it won't heat anything, all other items work
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwave oven.
Mar 03, 2009 | GE JVM1870 Microwave Oven
GE Advantium SCA1001SS Convection / Microwave Oven Logo
111 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
