Question about Datel Action Replay for Nintendo DS
Action replay ds doesn't detect software
My action replay isn't working right, after i turn on the ds, and insert the usb, when i open the action replay program, it doesn't detect the action replay, how do i fix this?
  • 40 Answers
Type in on google AR code manager cannot detect the AR for (after for type in the the type of your cpu like xp or vista) then click on the youtube video that goes with the stuff i just said
Posted on Apr 26, 2010
    Problem Solver:
  • 18 Answers
For some reason the wire gets messed up some times and the computer and DS can't connect to each other. I went and took a little bit of time to figure this out and I think that I may be the first person to figure this out.
Note: You must have your DS hooked up to the computer pluse the disk in the computer
1. Go to "START".
2. Next go to "Control Panle".
3. Get it on to the Folder type menu.
4. Click on "Add Hardware".
5. Let it run through for a min.
6. Ckick on the yellow "?".
7. And it should work so go to the "Action Replay Code Manager" menu.
I'll see if I can also post a walkthrough on YouTube for this.
Hope it works :u)
Posted on May 27, 2010
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
Aug 03, 2009 | Datel Action Replay for Nintendo DS
I wiped all my games! HELP ME!!!!!!!!!!!!!!
i had the same prob
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
from codejunkies
Jun 13, 2009 | Datel Action Replay for Nintendo DS
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
Why did my action replay erase every game and
Wilsonboys38, all you need to do is reset the system. I can't remember how to do this so check out www.codejunkies.com
Jun 10, 2009 | Datel Action Replay for Nintendo DS
My action replay zeroed out.
the ds cartridge need to be reset.
do it by using this method.
you can tell if it needs resetting by;
Jun 09, 2009 | Nintendo DS Lite Console
Action Replay code manager wont read me action replay
Your replay needs re-setting....
You can tell if it needs re-setting by...;
Jun 08, 2009 | Nintendo DS Lite Console
Action Replay DS has deleted avery single cheat code it came with
source codejunkies
May 13, 2009 | Datel Action Replay for Nintendo DS
My Ds Action Replay Went BLANK!
i have had a similar prob it wiped all the games andm then i could not put more on because it went multi coloured when i tried so i hap to reset the entire thing to do so(source codejunkies):
copyed from code junkies
Mar 20, 2009 | Datel Action Replay for Nintendo DS
My DS action replay is broken
If you hold A B START AND SELECT at the same time, with the power OFF, then turn it on with your thumb or something and let go when it says the product isnt endorsed with nintendo. hope it works good luck =)
Feb 06, 2009 | Datel Action Replay for Nintendo DS
Action replay when i plug in my ds and load code manager it says waiting for ds even though it is plugged in
IF you are running Vista 64, the issue is the driver on the disk is incompatible, thus the pc will never see the ds. However, I have found a workaround. First make sure the DS is on and plugged in and the Action replay Manager is launched. On the DS click on the mouse so it should read updating software. Then, go into device Manager via the Control Panel, there you will see NDS and an exclamation mark. Right click and choose to update the driver or properties. Then choose Browse My computer for driver software... then let me pick from a list... then fo the manufacturer shoose: Standard USB Host Controller and for the Model choose Unknown. It will pick it up instantlly. Voila.. Good Luck! and what a pain!! V
Aug 21, 2008 | Datel Action Replay for Nintendo DS
Datel Action Replay for Nintendo DS Logo
1,024 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
