Question about Maytag 24 in. MDB3700 Built-in Dishwasher
Cloudy glasses after washing
Trying to fix dishwaher my glasses after washing are coming out cloudy and a film on them ,.what do I need to do ?
  • Maytag Master
  • 43,501 Answers
Glassware cloudy or filmy
Soak the glasses in vinegar and rub the cloudy film off.
I find there is better luck with glasses, and we wash a lot of them, if you use rinse aid. Higher temperatures might also help, but opinions vary.
Oct 01, 2014 | Miele 24 in. G645SC Plus Free-standing...
Cloudy film left on all dishes and glasses. How do I remove the film?
Buy a gallon of white vinegar and rewash your dishes this time add 1/4 of a gallon of vinegar in the water with no soap just vinegar and water.... Also check and see if the dishwasher is completely draining you may have another problem that the dishwasher is not completely draining and you are washing with dirty water...... check the screen in the bottom of the dishwasher and the spray arm to see if they are clean and open...... I have used vinegar in my dishwasher and it has taken the cloudy film off... You may have to add it a couple of more times if you have a real bad build up......
I also use cascade complete dishwashing soap and has helped the problem with the cloudy film.
Mar 28, 2011 | KitchenAid Dishwashers
All glasses and plates have a cloudy film remaining after wash
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 21, 2011 | Whirlpool Dishwashers
Glasses in top rack are covered by an opaque film. Seems like the insides are collecting the most. I've tried the white vinegar wash and it worked the next time but the following load was worse.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Dec 18, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
After a wash cycle the dishes and glasses have a white film on them making them look dirtier than when the wash cycle started. What's the problem and what do we do?
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Sep 29, 2010 | Miele 24 in. Incognito G863 SCVi Built-In...
The machine does not seem to rinse properly. We have checked the water fill level, water temperature, spray arms are not clogged, have determined it is not a hard water problem and have tried Glass Magic...
Sep 23, 2010 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
There is a film on all the dishes and glasses. They look dirty when the wash is finished. You can feel the film.
Other things to try: CLR on the spray nozzles to loosen up cloggs.Check the filters to be sure they are clear.
Jul 14, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Glasses are not clean, come out cloudy and someimes have small food particles left on glasses
When the glassware comes out with a film on them (cloudy) the most common problem is a failed heating element. When it is repaired, the wash water will be heated to the proper temp to activate the dishwasher powder/detergent.
Please report back here what you find. OK?
Aug 10, 2009 | Frigidaire Dishwashers
Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Apr 01, 2008 | Bosch 24 in. SHE56C05UC Stainless Steel...
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
145 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
