Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Wont start like its getting fire.. starts with starting fluid like carb isnt working. what else should i try?
  • 23 Answers
Youll probably have to take the carb off and clean it real good.I sometimes can reuse the same gaskets depending on how old they are.
Posted on Apr 22, 2010
Why honda generator wont start eu30
First, see if there is fire to the spark plug. If not, then that is the problem. If there is fire, try a shot of starting fluid in the carb. If it starts initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 06, 2014 | Electrical Supplies
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
Aug 28, 2014 | Saws
Husqvarna kohler courage 20 hp wont start
Not sure what you meant by starting fluid didn't make a difference. If it fired (tried to start/run) after using starter fluid, then fuel flow is the problem. One technique I've used to troubleshoot a mower someone gave to me, is to place my hand over the air intake of the carb and see if I can keep it running by choking with my hand. For me, its worked, and basically it proved that the carb was bad. If this works, then try cleaning carb...replace needle valve and float if necessary. A repair didn't work for me, had to replace whole carb ~$80. If the solution is a repair is to the fuel system...do not spare expense in the future on using NON-ethanol gas or good additive that neutralizes the effects of the ethanol. Small engines, especially ones not used daily, will suffer damage from ethanol gasoline. A cheap price to pay for the aggravation your going through now.
Apr 09, 2014 | Husqvarna Garden
Torn down Yard Man wont start
Fuel related if you can get it to fire with starting fluid.
May 12, 2013 | Mtd Garden
917.374050 wont start
first check for spark if you do take off the air filter and spray some carb cleaner of starting fluid in the carb and try it if it fires then clean out the carb
Apr 02, 2012 | Craftsman 675 Torque 190 cc 21" Push Lawn...
We have a 84 dodge prospector she turns over but wont fire.........had battery checked is crancking out about 200 cca less then the actually battery is supposed to but still gets her to turn over.........
Shoot a couple shots of starting fluid in the carb. That should bring the old girl to life. The choke probably isnt working thats why shes cold blooded
Jun 13, 2010 | 1984 Dodge D150
Have a honda crf100f 4cycle got spark wont start,
CLEAN THE CARB AGAIN IF IT RUNS ON STARTING FLUID ITS NOT GETTING FUEL YOU WILL NEED TO REMOVE THE JETS AND MAKE SURE THEY ARE CLEAR
Jan 23, 2010 | 2002 Honda CR 125 R
98 rm wont start
hi fellow rider, you may want to check on the links below:
http://www.thumpertalk.com/forum/archive/index.php/t-726715.html
http://www.allthingsmoto.com/forums/f-62/rm-125-wont-start-31198/
http://answers.yahoo.com/question/index?qid=20081201165114AADfYoC
Sep 10, 2009 | 2003 Suzuki RM 125
Won't start, small engine guy said carburator needed to be flushe
Hi lackeyapda:
Fire Air Fuel
Remove the spark plug, plug it back into its wire. Hold it close to the metal frame WITH INSULATED PLIERS. Pull the cord and see if you get a spark. If no it is the coil, plug wire or a safety switch. If yes
put it back together. Take the air filter off. Spray some "easy start" or "carb cleaner " into the carburetor. Try starting. If it starts for a moment then dies, you do need to clean your carb.
Jun 30, 2009 | Honda Karcher G2400HH-R Pressure Washer
MTD yardman chipper wont start get spark need manual
I am successful too at using the starting fluid in the carb or directly into the clinder. That is how I start my MTD 5.5hp chipper. My problem is I have to hold down the primer bulb to keep it running. If not, the engine will stall.
May 12, 2009 | Troy Bilt Walk Behind...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
80 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
