Question about Toro Lawn Mower With Toro Power Tools
Mower will not start
Toro 6.75hp personal pace mower. will not start did not use last year did not put stabilizer in fuel
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. Sounds like your in need of a serious carb cleaning session:
You engine parts manual is here: http://www.briggsandstratton.com/maint_repair/manual_and_more/docmanualdetails.aspx?showpdf=ms2143_B_LO.pdf
Now lets go through carb cleaning:
Before you start.... if you have a digital camera take "close up" PICTURES of the linkages and springs attaching to the carb. If this is your first time you will be so glad you did. You can always delete them later if you don't need them. :)
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Localte the Air fuel Jet on the side of the carb and count the number of turns it takes to close the Jet adjustment until it is just snug.
4. Remove the Jet / Orifice in side of Carb (spring on screw stem)
5. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the float pivot pin.
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle valve It should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly
g. Fuel selector ON. Raise and lower float checking for free movement with fuel flow when lowered and stopped when the float is raised level.
6. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions.
Reassemble connections.
FUEL FLOW IS GOOD
NOTE: If you have carb cleaner spray it into the side needle jet hole.
7. Install air fuel mixture needle jet in the side of the carb. Turn until closed and then back of the same number of turns it took to initially close it snug before removal.
8. BEFORE you install the float bowl inspect the bowl nut. There are holes in the side of the nut where it screws in to the bottom of the carb that must be clear. (could be no holes in yours)
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it.
NOTE: This engine was made with 2 different carbs. One had a choke the other had a primer bulb. If the primer bulb has a hole in it the engine will start then die after a few seconds.
Thanks for using FixYa.
Kelly
Posted on Apr 23, 2010
  • Kelly
    Kelly Apr 27, 2010
    Just doing a follow up. Were you able to resolve your "NO START problem? If you need more help just ask.
    Kelly
Mower run for a while then shut off
Posted on Apr 30, 2010
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Toro timemaster is 3+ years old and doesn't self propel when you push the handle forward any longer.
Either the transmission is shot or the gears on the wheels that turn have been worn away;. They are plastic and do not last long nor take much abuse.
Apr 04, 2016 | Toro TimeMaster 30" 190cc Personal Pace...
Toro personal pace mower will not stay started?
If ir starts and runs for only a few seconds it's a dirty carb/bad gas. Drain the fuel system and use FRESH gas; change out your fuel supply monthly to avoid "phase separation" issues. If it runs for several minutes and then dies it is possibly a sticking valve. Do a compression check cold and after it stalls to confirm. Hope this helps
Mar 08, 2015 | Toro 20372 Recycler Personal Pace...
Toro personal pace 20372 starts, runs for 45 minutes then dies
Possible fuel blockage,or ignition source getting hot,electronic CDI unit ,check for spark at the plug when it stops.
Jul 21, 2014 | Toro 20372 Recycler Personal Pace...
Toro push mover starts then quits
Looks like a fuel problem. Remove fuel line from carb., should get fuel.
Nov 25, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
My Toro Personal Pace 22"
pull your spark plug and see if it will pull then, if so then it is hydro locked with fuel which can be caused y a bad fuel cap, not venting or a stuck open needle in carb causing gas to flood cylinder
Jul 27, 2011 | Toro Lawn Mower With Toro Power Tools
Toro 22" personal pace with key start. Just
Pull the air cleaner of to see if fuel is getting to carburetor. If it is then see if its getting fire to the plug by taking out and put the wire back on but be careful not to hold the wire or the plug if fire is week then get a new plug or get a new one and see it that helps
Jan 25, 2011 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
586 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
