Question about Ahead Software Nero 5.5 (NERO5.5) for PC
What is Burning Rights
Whenever I try to burn a CD using Nero Express I get a message statting that you do not have burning rights. The problem can be solved by downloading a free software from www.nero.com
But I do not find any software named "Burning Rights"
Please guide.
Regards.
    Genius:
  • 1,913 Answers
SOURCE:
Unable to copy music to cd by using nero7
First you need to locate your music/audio. If it was downloaded from Limewire/Frostwire the default location would be C:\Documents and Settings\**Your Username**\Shared
You can also access your music/audio through Limewire/Frostwire, by going to your Library, then highlighting a file that you want to burn and press explore. This will open the folder containing the highlighted file.
Alternatively use the search to search for something you know is in the folder you want to access or eg. search for the extension of the music/audio you want to burn.
First it may be worth mentioning that there are two ways of burning audio in Nero 7. Using Nero Express or Nero Burning ROM (The original Nero program). I find both very simple to use, but prefer Nero Express, so That's what I will use here.
First open Nero StartSmart:
Pressing add is not necessary. You can also open folders outside of Nero Express, and then you drag and drop the same way.
You can make mp3 disks using Nero Express as well. Just choose make Data Disk instead of Audio CD in Nero StartSmart. The only difference you will see is that instead of minutes you will be adding size (MB)
In case you run into playback issues when using Nero Express, then you have two options. You could try using Nero Burning ROM. Raaf explains here how to do that with Nero 6, but Nero 7 is very similar:
Burning a (audio) CD from your MP3's (Windows)
Another way is to run a tool called CD/DVD Drive Speed (can be found in Nero StartSmart under Tools, where you let Nero burn test disks for checking the best speed for this type of disk.
Aug 03, 2012 | Ahead Software Nero 7 Essentials Suite...
Whenever i burn a dvd with Roxio "Easy" CD &
The service packs are trying to stop pirating software.
Not very good software. TRY Nero Express and Power DVD
http://www.nero.com/eng/downloads-nero10-trial.php
Feb 10, 2011 | Roxio Easy CD & DVD Burning
Nero express burning problem
There is a big chance that your CD/DVD is defective or your CD writer. Have you tried burning another CD?
Jan 05, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
No burning rights
windows vista has a thing about admin rights and you can check every box and it says you have rights but you really don;t.
and there is now significant admin user in vista anymore.
here is what i had to do to get the rights to do anything.
Please understand that editing the registry is not for the weak computer person and you must be able to reverse any changes made that cause an issue. I used this on mine and it helped me gain some control.
click start and run,
type in regedit
when Registry editor opens
click on HKEY Local Machine
click SOFTWARE
click MICROSOFT
click WINDOWS
click CURRENT VERSION
click POLICIES
click SYSTEM
HIGHLIGHT SYSTEM
in the area where there are values right click and select new/ DWORD
enter "EnableLinkedConnections"
press enter
right click EnableLinkedConnections and chose MODIFY and change the value to 1
Save and exit Registry Editor.
Reboot your computer and try Burning again.
It sounds scarey but it's not and just remember or write down these instructions so you can refer to then easy during the process.
and also to reverse the entry if needed.
if you need any further help let me know.
Good Luck
Jun 05, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Install NeroBurnRights required
You are trying to copy a copyrighted cd .There should be a setting in nero which allows you to turn this off as you are allowed to make backups
of your own goods for personal use Try to find it !
Apr 22, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
How to burn cd?
There are 2 ways of burning a CD.
1) From Windows operating system
2) From a CD burning software like Nero
Solution
If you are using Windows to write a CD follow the proceedure:
1, Select all files you want to write on cd
2, Right click on files and click on send/copy them to writable CD
3, now brows CD from my computer
4, click on menu>write files on ZCD
that's it
If you are using Nero
1, Start nero express
2, Select Data CD from menu
3, Now on the opened pane click on "Add"
4, After adding the selected files click on "Burn"
That's it
Regards
Jan 18, 2009 | Ahead Software Nero 6 Ultra Edition...
Nero trouble shooting
Most likely you're having hardware issue.
Please concider replacing your cd/dvd burner asap.
Thank you for using agadycom.
Nov 20, 2008 | Dell Red Hat Enterprise LINUX WS Version 3
Burning DVD-R playable on a stand-alone DVD Player using Nero Express 6
http://www.softpedia.com/get/CD-DVD-Tools/Data-CD-DVD-Burning/Nero-8.shtml
please go to the above site and download nero 8 which is more advance and enter the any of the keys
9K20-7839-0295-6KA4-5008-1KM3-8C64 (the one i recomend)
1K22-0867-0795-66M4-5308-3698-EE5M or
1K22-0867-0795-66M4-5251-9214-3AC7 or
1K22-0867-0795-66M4-5765-3212-7AA2 or
1K22-0867-0795-66M4-5085-3781-ACK0
good luck
Apr 20, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Burning and playing the product
see the burning rights that nero has set in your windows... it might be due to unupdated burning rights... try updating your nero using nero productsetup tool...
Feb 18, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Problem on burning CDRW
run the nero drive speed first before burning in your files, if your cd in a RW or rewritable, just erase it and burn again the data's that you want.
Aug 25, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Ahead Software Nero 5.5 (NERO5.5) for PC Logo
167 people viewed this question
Top Ahead Software Computers & Internet Experts
Ekse
Alun Cox
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
