Question about JVC XV-F80 Multi-disc DVD Player
Player says "Hello" then "loading..." then "No disc" and won't open or recognize any commands other than on/off?
  • amyjared Apr 22, 2010
    I did leave it unplugged for a couple of hours and then plugged it back in to no avail. I will try to clean the lens as per your instructions and let you know if that works. thanks!
    Could not identify lens with cover off. Where exactly is it located and what exactly does it look like? Thanks
  • 10,515 Answers
Have you tried to unplug and plug in the Device after few minutes, say 30 minutes?If not, try it.
It is quite a common problem with this model, you can try a clean on the lens,you can use a DVD cleaning kit which you can buy from Radio Shack or similar or you can clean manually.
To clean manually unplug from wall and leave two minutes.Remove cover identify the lens as a small round glass lens in the DVD tray assembly.Clean with the glass lens with a cotton bud or similar, use a small amount of isopropyl alcohol or do the clean dry, any other cleaning product could damage the unit.Remove any foreign objects in the unit.Reassemble and test
If no luck then you will need a new laser assembly I'm afraid.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 22, 2010
  • taran_2005
    taran_2005 Apr 22, 2010
    Thanks for your response!!
    I would be waiting for the Update.
    Hope i
    helped you.
  • taran_2005
    Look at the below Pic :-
    Let me know,if needed further assistance.
    Hope i
    helped you.
Pioneer DVD 717 - Not Loading Discs Whenever I load a disc, the player spins the disc for a moment before slowing down. to a stop. It repeats this around four times in succession before it then opens...
Hi msaslloyd ,
This could be because of a damaged lens , where the dvd player tries to recognize the disc but is unable to do so and then either sends the disc back i.e. the tray opens up or the message no disc loaded is displayed.
I suggest you to :-
  1. Clean the lens with a lens cleaner available in the market and load any disc in the player to check if it's working fine.
  2. Get the lens replaced from the market and the problem should be solved.
Hope this helps ..:)
May 10, 2011 | Pioneer DV-717 DVD Player
Samsung dvd player does not read dvd disc.it reads "no disc".
I also have a Samsung Dvd player. If it is a dvd you burned yourself it may not recognize the disc. If you have loaded a purchased or rented disc and it still won't load, I would say the head is dirty or the unit is defective. I would try a head cleaner first.available at most electronics stores If that doesn't work you probably will need to send it in for repair.
good luck
Apr 15, 2011 | Audio Players & Recorders
Disc won,t play it just keeps spinning it says loading but it won,t play
how long have you been using this player and when did this begin?
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
Jan 12, 2011 | Amphion Mediaworks V101 DVD Player
DVD PLAYER DOESNT RECOGINZE ANY DISCS
The reason your DVD player is not reading any disc is either because the lens is weak or bad.
If it is weak, it will be selecting discs, but if it is bad it will not recognize any disc at all.
In your case the lens is bad and need to be replaced.
Unplug the television and unscrew it open, then you will have direct access to the disc tray and lens, unscrew the disc tray and disconnect the lens from the ribbon that is connected to it and replace it with a new one then reverse the process to reassemble the player together.
You can first use a cotton bud to clean the old lens (the crystal or glass like tiny object clipped between a kind of plastic) and try to play a disc to see if it will recognize it.
Take care and good luck
Oct 31, 2010 | GE 1106P DVD Player
Sony dvd player will not eject disc: "Disk Error" displays on screen then it will try to load over and over. It will not respond to open?
Try unplugging and re-plugging. If the does not work try to start the Player without letting it load. i.e. give it a separate command before trying to eject disc.
Aug 17, 2010 | Sony Televison & Video
Says loading disc then no disc pops up and it just won't play. Tried the phillips lense cleaner still does same message (loading the no disc)
The reason the player keeps loading and showing no disc is simply because the lens of the player is weak.
To fix this,
  1. Open the cover of the player with the appropriate screwdriver,
  2. Open the disc tray,you will see the lens, like a crystal or diamond like object,
  3. Replace the lens by removing it with the mechanism that supports it and fixing the new lens,
  4. Test it with a DVD disc.
  5. Cover the player back.
Take care
Jun 21, 2010 | Televison & Video
Why won.t the disc go to load. it keeps opening after inserting disk .when play is pushed it shows stop then ejects disk.Whats up with www.rca.com/customersupport
check the type of discs that are recognized with your dvd player. Some machines recognize dvdr- some dvdr+ some dvdrw+/- you may be using the wrong formated type of disc.Look at disc and see what type it is in the ring surrounding the hole especially if it is a copy
Sep 29, 2009 | RCA Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
3 yr Old CD Player not recognizing discs
Laser might not be faulty but just a dirty lens/ rail assembly.
If thou darest open the thing, clean the lens ( GENTLY) with a swab of glass lens cleaner. Clean the chrome runners for the optics assby with a swab lcaed with WD40 or silicone.
Aug 01, 2007 | Yamaha CDC-565 5-Disc CD Changer
JVC XV-F80 Multi-disc DVD Player Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
