Does not turn on keeps blowing on board fuse - Televison & Video
    Genius:
  • 1,175 Answers
You have a main power supply failure..Needs replacing
Posted on Apr 22, 2010
88 toyota pick up v6 keeps blowing efi fuse
you may have a short of some kind, when a fuse blows repeatedly it is no good just replacing, you are being told that something is wrong with the equipment.
You will almost certainly have to visit a technician for a diagnosis. It is unlikely to be something that an inexperienced end user can sort out I am afraid.
GOOD LUCK
Oct 26, 2015 | 1988 Toyota Pickup
Fuse for dash board lights and tail lites keeps blowing
You may have a damaged wire leading to one of the lights that keeps blowing.
Not fun, but you have to chase down the wiring to everything that keeps blowing out.
Mar 19, 2014 | Ford Focus Cars & Trucks
The fuse keeps blowing inside the edenpure heater
Generally speaking, fuses blow when too much current passes through them. Typically this happens when there is a short circuit some place. a connector or bare spot in a wire touching ground, a bad component on a circuit board, a bit of conductive debris on a circuit board all can cause shorts. If the fuse blows, it's doing its job to protect you from a problem you have yet to find.
Dec 01, 2013 | EDENPURE USA1000 Infrared Heater
1993 Goodman gas furnace keeps blowing fuse when first turned on
You can take each thermostat wire off the control board and use a ohm meter and test to ground, should not have any resistance. Another way is turn off power take each wire off the board, then place one wire at back on the control board terminals ome at a time, untill the one you get to the one that blows the fuse. If the wires check out good sometimes the thermostat itself can have a internal short and cause the fuse to blow.
Nov 27, 2012 | Heating & Cooling
ATTn SD Tech: my 65" Mitsubishi keeps blowing the
1,2 means no error found. To confirm turn set off and unplug and and turn back on, when it fails try the self check again.
Where did you buy the replacement fuses? Radio Shack?
Some of these fuses are special and the poor ones which are generic will pop for no reason sometimes; examine original fuse and holder for correct amperage and type of fuse used.
sd tech
Sep 09, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Blows fuse when turned on
this is a normal behavior if one of the power supply transistors have blown. take the unit to an enlectronics repair. they can either change the transistors affected (usually more than one) or replace the power supply board.
May 29, 2009 | Sansui DTV3200 32" TV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Thermal fuse keeps blowing
Mr. Larry (guru?)
The thermal fuse is just that It doesn't protect the circuit from over current although it certainly can open in that case. It is there to protect the board from overheating , thus the term thermal. The dishwasher could be allowing the water to heat too hot or the water heater in the home is turned up too much. The heater could also be shorted to case thus allowing it to be on even though the control is not calling for it especially if the polarity is incorrect to the dishwasher or the relay on the board could be welded closed so that the heater can't turn off even though the thermostat is satisfied. The best thing is to get a person who can check these things. You don't necessarily need to change the board with a fuse. I have changed many fuses with no other problems and verified that the machine was still working years later. sometimes the fuse just blows!
Dec 02, 2008 | Dishwashers
Blowing fuses in power supply
One thing to check, would be the filter capacitator that is on the front circuit board. They are known to become shorted. The cap is fairly large, and may be mounted on the side of the circuit board that faces the front panel. Clip one lead, and apply power. If the fuse does not blow, then that is it. A second possible component, is the polarity protection diode, that is near the power jack, next to the fuse. If it is shorted, then the fuse will blow every time.
Aug 21, 2008 | Optics
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
