Question about Whirlpool LER4634J Electric Dryer
Will not heat up
Dryer is about 3 yrs old,minimal use
worked fine until it was moved to new location
was transported upright but had to be layed down initially to get into vehicle
  • 6,784 Answers
HI. There are a few areas i would advise to check to resolve this issue.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again. The most common cause of overheating will be a clogged ventilation assembly. Be sure to inspect the entire ventilation Assembly for build up. This will cause issues, if obstructions exist.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Posted on Apr 22, 2010
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
The top section, fridge, is freezing up, we only had it 3 days
Read somewhere that refrigerators are not supposed to be transported on their sides - that they are supposed to be moved in an upright position and that if you have transported it like that you are supposed to let it stand upright for about 8 hours before using it.
Mar 17, 2015 | Electra GENUINE Refrigerator Fridge...
My amana upright freezer was working fine, but transported it to another location when I plugged it back in, it started to make a buzzing noise. How do I turn this off or fix it?
Hello....First...when you transported the freezer...you must sure the unit stays in the vertical position and not laying on it's side...back..or front....If the freezer is making buzzing noises...adjust the thermostat setting down until the buzzing stops...and increase the setting gradually until the desired temp is reached...it could take 24 hours for it to stablize...I hope this was helpful.....PEACE.......
Jan 19, 2012 | Amana Freezers
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
I just sold my Magic chef refrigerator (20.8 cu ft). It was 2 years old . I plugged it in for the buyer. It got cold as it worked perfectly. the buyer said he was going to lay it down to transport it...
i have been i the appliance service industry for approx. 18 years and everytime i see someone lay a refrigerator down or talk about it i literally cringe.... it can be done and sometimes will work ,but what happens if it does not sit upright and notice i said and all the oil runs back down it will fail everytime.... the oil gets in the evaporator and then will not run correct when the compressor comes on it pushes that oil through system and will clog capillary tubes and or slug unit creating it not to pump properly.... guarantee this is what happened to the unit... if it indeed worked fine before you sold it he either allowed oil to saturate the evap coil or something in the sealed system broke in transport causing freon to leak out...
Jan 26, 2011 | Magic Chef CTB2125 Top Freezer...
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
I have a toshiba 65H82 tv i need to move to my new house. can i lay it down or does it have to be upright?
Move it upright best for the tv.These tvs have chemicals in it three CRT tubes colors guns.
Sep 08, 2010 | Toshiba 65H82 65" Rear Projection...
I need to know if it is possible to transport side by side refrigerators laying flat. or almost flat. This will be a short move for about 1/2 hour.
Hello, Yes you can move your side by side laying on it's back..it is most important though that when you have it in it's new place you leave it unpluged for 24 hours so the oils can run back into the compressor. If you have any other questions please feel free to comment again...Mike
Aug 24, 2009 | Refrigerators
Moving
Enclosed find a link were you can get the answer for your question. http://en.allexperts.com/q/Moving-Furniture-2016/Moving-refridgerator.htm Good luck !
Aug 16, 2007 | Magic Chef CTB2125 Top Freezer...
Whirlpool LER4634J Electric Dryer Logo
15 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
