Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Timeing pull cord rip out of hand when trying to start mower model 18m
  • 110 Answers
What you have done is sheared the flywheel pin top of eng pull fly wheel you will find a schered pin go to lawnmower shop possible with pin get replacement just a few dollars you be back in timing and back to work let me know if you need a walk thru sparks
Posted on Apr 22, 2010
Model 944.361200.mower won,t start in colder weather,once temp gets above the70degree mark it will start,but blue smoke comes form exaust.mower will start right away every time once engine is hot.fresh gas...
I have a mower with a Honda 165cc engine that is temperamental as far as the initial start up is concerned.
Once it has started it always fires up first pull
The problem seems to be the gas is slow to reach the carb / cylinder
I have developed a ritual for starting up.
Open the gas tap.
Lean the mower back until the hand bar touches the ground.
Raise the mower and lift the hand bar so the back wheels are off the ground for a few seconds.
Fully open the throttle, Hold the ignition control back and operate the pull cord.
If it doesn't start first time I am usually rewarded with a promising fire-up.
Sounds wacky but works for me and used to spend 20 to pulls on the cord to get it to fire .
Oct 24, 2017 | Garden
My pull cord rips out of my hand
The string assembly should reach a point far enough out when you pull the cord that it lets it spin free of the engine. What you are probably experiencing is the engine kick-back, where the engine is compressing the air/gas in the cylinder, and the pressure pushes the engine back. The crankshaft is connected to the pull cord assembly, so it's pulling out of your hand. You may not be pulling hard enough, or the cord assembly needs replacing.
Aug 01, 2012 | 5.5 HP GX160 Engine
When yanking on the pull cord to start engine
Im guessing that you have started it before, so I guess , check that its not flooding ,pull air filter out see If you can see heaps of fuel in the bottom hole ,if you do take spark plug out pull cord a few times without holding start cable or you will catch on fire replace spark plug try starting ,no start still flooding take it to a lawn mower place ,float may have a hole in it , if not flooding, on the bottom of the cardy one brass nut , four holes find them clear then, start also a brass pipe going into the center of the carby is probable blocked
Jun 18, 2010 | Mtd 22" Yard Machine Push Mower
When trying to pull start a briggs 6hp roto tiller motor, it fires then rips the pull cord out of my hand, seems like it want's to start in the opposite direction?
DID WE CHANGE THE MOTOR ? THE BLADE ON A LAWN MOWER ENGINE IS THE FLYWHEEL. IF NOT IT SOUNDS LIKE THE KEY IN THE FLYWHEEL IS SHEARED , THIS ALSO WILL CAUSE THIS PULL CORD ISSUE... .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Dayco Garden
I have a TROY-BILT model 566 Smart Touch mulching mower. The starter pull cord (for lack of a better term) did not rewind when I tried to start the mower last weekend. I rewound the cord once by hand and...
sometimes these are shot dogs; these are what come and grap the engine and the cord is loose for about an inch or two and then you feel restance from the engine commpresion to start these DOGS are plastic and cheap
Apr 10, 2010 | Troy Garden
Bolt comes loose and rip cord is yanked from hand
  1. block off the blade and driver assembly with a 2x4 to keep it from moving
  2. remove the flywheel nut (regular hand force should be sufficient)
  3. tap the 3 holes on the flywheel (if they aren't already threaded) using 1/4inch 20national tap set
  4. remove the flywheel using a flywheel puller -- a harmonic balancer puller which matches the tecumseh bolt pattern on the flywheel also works using 3 1/4inch thread (20national, 2inch long) bolts with washers
  5. NOTE: (if the blade was removed/reinstalled, tighten the blade to manufacturer's spec of 60lbs) before installing the new flywheel key
  6. remove the sheared flywheel key
  7. clean up the flywheel (wipe off all the dirt and grease)
  8. install the new flywheel key (part 611004 for toro 20016)
  9. install the flywheel (pull the bail brake handle to get the ball-brake inside the flywheel)
  10. tighten the flywheel nut to manufacturer's spec of 37.5lbs
  11. prime the gas bulb, give it a pull and mow away
Aug 24, 2009 | Toro Lawn Mower With Toro Power Tools
Cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Aug 21, 2009 | Garden
Motor turns, but cord rips out of my hands when starting
sounds like timing issue check the flywheel key and see if it sheared. could be the valves also but i doubt it.
Jul 27, 2009 | Toro Lawn Mower With Toro Power Tools
I got a Craftsman Eager 1 6.75 Electric start mower from a friend but it will not start, the electric start does not work (is there a fuse?) for that, I tried a new 12 volt battery NOTHING! Then when I...
There is a charger plug that needs to be plugged in to to an A/C charge adapter that plugs into a wall outlet looks like a wide plastic gator clip they break easily. Make sure your friend gave you this adapter.
Make sure the rechargeable battery you jus bought is fully charged the usually need to be plugged in for 48 hours for full charge to occur. If all this is good change the spark plug. If this does not o it call a local mower repair place like Tony's Not SEARS but first look on your mower there will be model numbers. You will 1 on the engine 6-10 digits and at least 1 if not 2 on the frame this will tell the repair shop all they need to know. To replace your pull recoiler Good Luck To You!!
Jul 08, 2009 | Craftsman Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
190 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
