Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch washing machine, WAS24460UC, error codes
Got an F:36 error code. Turned machine off and now get an F:34
  • kress73
    kress73 Nov 28, 2012
    Hi Everyone i am getting F 67 from start up does anyone know what F 67 means?
  • 10,515 Answers
Unplug the Washer for Few Minutes, say 30 Minutes, and then Turn it ON. If the Error Message would not Reset, Read the Information Given by Bosch for this Error :-
However, for a washing machine Bosch list E34 as a door lock fault.
The following is from the service manual.
door lock is broken SAFETY ERROR - switch ON/OFF for reset Normal mode
- door hook is stuck - washing program is aborted - check door lock
- door is stuck - door is unlocked, if possible - check mechanic
- stiff gasket - operator control actions are blocked - check wire harness
It appears you have a problem with the door lock assembly.
Have a look at it, if it's not locking when the door is shut, I'd suggest replacing the door lock on a "fit and see what happens" basis. It's not overly expensive and would be worth trying first. Check all the items mentioned above and let me know how you get on.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 22, 2010
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Error code 141. How can I fix it?
Bosch error code 141 Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > error code 141 > Washing Machines
Bosch washing machines error code 141 related questions and answers. Ask your Bosch questions. Get free help from washing machine experts.
error code 141 Washing Machines Questions & Answers ...
Washing Machines error code 141 questions and answers. Ask your error code 141 washing machine questions. Get free help, advice & support for popular ...
Zanussi Washing Machine Fault Code Reset - iFixit
https://www.ifixit.com/...Washing+Machine+Fault+Code.../34977
iFixitMy Zanussi Washing Machine hasn't been working properly for a while. then it stopped spinning and emptying, then wouldn't go through the programmes at all.
[PDF]TOP LOADER Automatic Washing Machine - you
Dec 29, 2015 | Washing Machines
What does F43 error code mean will I need to get a technician
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 12, 2014 | Bosch WAS24460UC Front Load Washer
I have a WAS24460UC Bosch washer. It won't drain. The pump runs, sounds like it has an air pocket or like the pump is running backwards? I have had a F34 and an F18 erro code.
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hoses from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 10, 2009 | Bosch WAS24460UC Front Load Washer
Error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
Jul 28, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
976 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
