Question about Acer Aspire 5100 Notebook
Right-click button has collapst on bottom side. have to click at top of button
The supporting springs(?) under the right "mouse" button has broken. I have to click on the top side of it to activate a right-click. I need instruction on how to get to the underside of it to determine if it can be fixed.
  • troutmon Dec 06, 2008
    Sorry, but apparently you've answered my question long ago, and shortly after posting I figured it out. As I recall, it seems your instructions are correct, but since I'm in the middle of another project, I don't have time to dis-assemble my laptop to confirm. (OK...I probably wouldn't anyway, just to confirm...but thanks nonetheless!)
    Kent
    Sergeant:
    Champion:
  • 244 Answers
To disable Aspire 5100.
1. remove battery, harddrive.
2. open all cover on the back of laptop.
3. removed wireless antena cable from wireless card.
4. remove power cover (power cover is cover that have power button)
5. removed 2 screws on the back that hold lcd.
6. removed 4 screws that hold lcd. (now you can remove lcd).
7. remove 2 screws on top that hold uppercase from lowercase.
8. remove all screw on the back.
9. remove heat sink, and remove 1 screw under heat sink.
10. that's all, you can remove uppercase and repair it.
i hope this help you. good luck
Posted on Mar 23, 2008
How do I return "Add a program" to the Control Panel under Programs?
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 and windows 8 once you open the mouse you will see mouse and keyboard center link mid page click on that to change your mouse right click
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp. In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Hope this helps.
Dec 29, 2012 | Dell Inspiron 530s Desktop Computer...
Tip
How to change the mouse sensitivity
<p>Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.<br /> <p><br /> <p>Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.<br /> <p><br /> <p>Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."<br /> <p><br /> <p>Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.<br /> <p><br /> <p>Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.<br /> <p><br /> <p>Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.<br />
on Dec 07, 2010 | Computers & Internet
How to unlock a mouse on a laptop
On the top of your keyboard there should be F keys like F1,F2 etc.
Every F key has a little picture.When you see a touchpad picture press Fn+F5. According to my Laptop. For example if your touchpad picture is at F6 then you would press Fn+F6.The Fn key should be located near the ctrl keys. If this does not work then try the following steps:-
1 Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel."
2 Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link.
3 Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button.
4 Click the "Apply" button and then click the "OK" button.
Apr 30, 2012 | Dell Computers & Internet
On touch pad, the left and right click below the pad, for the mouse, the left button doesn't click anymore?
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Jun 09, 2011 | HP G70-460US Notebook
I can`t find my mouse driver for Windows XP. Mouse number is M-SBF96 Tank You for Your help!
1.Open the llink : http://www.logitech.com
2.On top the 3rd option is SUPPORT. Click on Product Support under it.
3.Type M-SBF96 in the box under the 2nd option which is "Option 2:
Enter model number or product name"
and click on the symbol on right hand side.
4.Search Results will show "Optical Mouse PS/2
M/N: M-SBM96B,M-SBF96 "
5.Click on "Optical Mouse PS/2 "
6.On the right hand side under "Software Downloads" click on the download link .
7.Select the correct OS and download the driver.
For more information refer to the link mentioned below:
http://www.logitech.com/en-in/support-downloads/downloads/mice/devices/3358?WT.z_sp=Model
Waiting for your Feedback >>>>>>>Do Reply !!!!!!!!!!!!!!!!!!!!
Mar 11, 2011 | Logitech M-SBF96 Mouse
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
Microsoft Wireless Laser Mouse 5000 Magnification Issue
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Dec 17, 2009 | Microsoft Wireless Laser Mouse 5000
Mouse double clicks when i single click. sometimes doesn't click.
If this is the same problem that the Microsoft IntelliMouse Explorer 3.0 is susceptible to, it can be fixed! It is a hardware issue that is caused by corrosion on the metal contacts inside the buttons. The corrosion prevents electrical signals from passing between a copper plate and terminals above and below it. You can carefully scrape the contact points with a knife to expose the clean copper.
Follow these instructions at your own risk.
To get into the mouse, peel off the pads on the bottom and unscrew the screws, then carefully pry the shell apart. Do I need to say disconnect your mouse from your computer? Attached to the circuit board inside the mouse, you will see a couple of black boxes.
Look closely at one of the boxes and see that there is a cap with ears that clip onto the bottom half. Wedge a blade into one of the seams between the ears and the bottom half and it should pop up a little. The dull side of the blade should be touching the circuit board. Be careful to not bend the ear. Pop the other ear up and the top of the box should come away.
Study the internals of the black box. At rest, the copper plate is held in place by three contact points: at one end by a pivot point; in the middle by the end of a flex-spring; and at the other end by the upper terminal. When the mouse button is clicked, the copper plate is pressed at its center until the spring gives way and the plate pops down to the lower terminal. This is called a "mousedown" event. When it pops back up to the upper terminal, this is known as a "mouseup" event. In quick succession, mousedown + mouseup = click. If the plate or one of the terminals is corroded, the mouse can become confused, and single-clicks get registered as double-clicks.
Warning: the plate is tricky to put back in! To remove the plate, pivot it to one side, away from the terminals. Be careful to maintain control of the plate. It is tiny and springy, so it likes to fly away. Unless you have very small hands, you need to use tweezers to handle the plate.
Check the contact points on the top and bottom of the plate for corrosion. You can use isopropyl alcohol and a toothpick to rub the corrosion away. Be careful to not bend the plate. If the toothpick and alcohol are not enough to expose the copper, scratch gently and evenly with the tip of a knife blade.
Do the same with the upper and lower terminal.
Now is the time for the most frustrating part. Due to its tiny size and being spring-loaded, the plate can be extremely frustrating to reposition. In my experience, it seems that the easiest way to put the plate back in place the terminal end under the top terminal, then position the spring in the middle (there is groove where the spring is supposed to rest), then use tweezers to pull the opposite end against the force of the spring and seat that end in its groove. Meanwhile, I hold a finger against the top of the plate so it does not fly away if the tweezers slip.
When the plate is successfully positioned, press on the middle of the plate to make sure it clicks up and down the way it is supposed to. Clip the cap back on the black box. You may have to turn the mouse upside-down to do this so the white piece does not fall out. Screw the shell back together and stick the pads back on.
Now, if you didn't break anything, you just saved $30.
Mar 31, 2009 | Microsoft Wireless IntelliMouse Explorer
I have a Canon PIXMA iP2200. It has started printing so small I can barely read it. Also it goes off the right hand side of the page so misses the end of sentences. Can you help.
Scaled printing
  1. Access the printing preferences by opening the printer Properties/ Preferences.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
Dec 12, 2008 | Office Equipment & Supplies
Acer Aspire 5100 Notebook Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
