Question about Maytag Neptune MCE8000AY Electric Dryer
Wont turn on, just buzzing sound
When moving the dial to the start position, it wont start upon pressing the dial in. Instead, there is just a buzzing sound.
  • Maytag Master
  • 43,501 Answers
Sounds like a bad motor for you...
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 23, 2010
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
Apr 25, 2017 | LG WM Washing Machines
I have 2000 john deere 420 and it wont turn over
The starting circuit is dependent upon the clutch safety ans PTO being off. Here are some steps to take:
1. Ensure battery is fully charged
2. Turn key on and turn PTO on then back off. Listen for clunk
3. Press clutch in fully and turn key to start position. If still no sound at all, hold key in start position and move clutch foot up and down, listening for solenoid click. If click but no crank, starter or solenoid or battery cable connection is bad. Start by wiggling cables, looking for any looseness. Next check solenoid and cables. If that doesn't fix it, starter or solenoid may be bad. There may be a fuse in the circuit. Check them out also.
if it cranks but doesn't start, you have a fuel or ignition problem. Good luck. Let us know what you find
Jun 22, 2014 | John Deere 420,1020,2010,2020,2510,2520...
The blower would not shut off, it kept blowing cold air. My repairman came and we saw the silver dial was in the completely upside down position (the 3 pointers were at the top). The pointers were set at...
The dial positioning does not really matter as this is a thermometer of sorts. It is a thermo controlled switch, upon reaching the desired temperature it turns on the blower and upon cool down it shuts off the blower. The dial positioning is not necessarily critical but with him turning it he could have damaged it meaning that instead of registering at say a set 150 degrees it may actually be more than 150 or less than 150 and it will work just the set temperature may be wrong. Confusing isn't it!!
Dec 25, 2010 | Honeywell L4064B2236 Fan/Limit Control...
We have the intermatic timer Model EJ351 and when I go to set the timer at the beginning it does not flash. It is when I start from off to on. Mary Ann
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Rotate the time dial clockwise at least one click, stopping at
the half hour nearest to the present time.
NOTE: During programming, be careful not to press the
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
Press the dial once to set the present time. The Red indicator
light will go off.
Rotate the time dial clockwise to the first desired ON time.
The Red light will pulse momentarily with each click.
Press the dial once to enter the ON time. The light controlled
by the switch timer will turn ON.
Rotate the time dial clockwise to the desired OFF time.
Press the dial once to enter the OFF time. The light controlled
by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting.
Continue to rotate the time dial until the Red indicator light
comes ON and stays ON, indicating that the switch timer is in
AUTOMATIC mode.
Dec 02, 2010 | Solar Intermatic Ej351c Indoor Wall Switch...
Bosch 500 series washer E:27 error code?
turn dial to off. hold down both delayed start and spin select buttons and turn dial to the left one click, to the cold position. keep holding button until you here a click. let go of buttons and turn dial to off. Every thing should go back to normal. Just fixed mine and all is good.
Nov 21, 2010 | Bosch WFVC5400UC Washer
I tried to start the dryer (whirlpool LE5700XK or the LG5701XK, not sure which) and when I hit the start button there was a loud buzzing noise, but no start. I turned the dial to the off position, and then...
Could be a couple things, depending on the buzz you are getting, if it's a buzz from the board like an alarm, it could be a door switch, if it's an electric sounding humming buzz it could be something stuck in your blower wheel like a sock
Jun 24, 2017 | Whirlpool Dryers
Fisher & Paykel D04 dryer, makes a load buzzing sound when I turn the dial to any "on" position. Any ideas?
Yup... you have a bad motor... the buzzing is the motor trying to start and not starting...
You will need to replace the motor...
Check out this tip for further info on this problem...
heatman101
Mar 30, 2010 | Dryers
Maytag Neptune MCE8000AY Electric Dryer Logo
175 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
