Question about HP PSC 2410 All-In-One InkJet Printer
When I power it up it starts clicking .Sounds like it is missing a gear.
Need help my Busa started to miss backfire a little smoke was only when I changed gears
Gavin, sounds like a bad plug or a coil on its way out.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
Feb 15, 2016 | 2003 Suzuki GSX 1300 R Hayabusa
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Turn key, makes clicking noise but not start.
Double check your battery connections. If the battery is new and the starter makes a series of clicking noises when the key is held in the start position than you are not getting a good power supply to the starter or there is not a sufficient ground.
Aug 01, 2012 | Cars & Trucks
Yamaha ttr 125 kickstarter won't grab
sounds like the gears inside are stripped or missing teeth open up the side case and check and replace any gears missing teeth or stripped
Jun 26, 2012 | 2005 Yamaha TT-R 125 L
I tried starting my 2004 Vstar 1100, it started turning over then just went to a spinning noise. I'm thinking a starter. What do you think?
This sounds very much like the gear on the starter may have broken. Less likely is that there is a tooth missing on the ring gear its self.
Try putting the bike in gear and ushing it forward a couple of inches so it turns the engine (and the ring gear) slightly. Try the start button again. If it now works then you have a tooth missing from the ring gear, if it doesn't then the gear on the motor has a problem. Easy to remove and check, The starter is located (If you didn'y know already) right at the front of the engine.
Sep 11, 2011 | 2004 Yamaha V Star Classic
Can an engine miss fire in two cylinders and not be noticed? In the truck on the highway, I use excessive gas and getting about 7-9 mpg. Also, I go into a low gear of about 1900 rpms with no power or high...
It sounds like you have two different problems. First it sounds like you have a transmission problem. It sounds like the band for 2nd gear is bad. As for the fuel milage problem, Is the check engine light on? If it was only running on 6 cylinders you should feel it.
Nov 04, 2010 | 1998 Dodge Ram 1500 4WD
When turning temp to heat from cool (blue to red) get clicking noise and no heat
if its a newer model sounds like the blend door motor's gears are broken take it out and seperate and check the gears for missing teeth
Sep 26, 2010 | Ford Explorer Cars & Trucks
Everytime i shift into second gear it always clicks out of it whats wrong with it???
Sounds like the dogs on second gear of the transmission are damaged, and likely also the shift fork. This is common in second gear, especially if it has missed shifts at high rpm.
Aug 17, 2010 | 1998 Yamaha YZF 600 R thunder cat
Oscillation stopped working!
Sounds like the drive gear is stripped.
Nov 20, 2007 | Bionaire BAP1500-U Air Purifier
HP PSC 2410 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
