Question about HP PSC 1315 All-in-One Printer (Printer/Scanner/Copier), Retail
Printer Problem I've replace the ink on my hp 1315 all in one because the low ink level was flashing on the printer. I place a new cartridge but the low ink level light would not go off and I cannor print anything What do I do?
  • Chicocaribe Mar 24, 2008
    How can I do a Head Alignment when the low ink level light is flashing?
    While this light is flashing, nothing can be done with the printer
  • Anonymous May 10, 2009
    exact same problemm
  • 667 Answers
Do a print head alignment. This should fix you up. If not add a comment and I'll be glad to come back and help you out.
Posted on Mar 24, 2008
I only want to scan but need a new cartridge - do i have to replace cartridge before scanning is enabled.
You will need a new cartridge before you can scan.
What you could try is to remove both ink cartridges.
Turn printer off and unplug from outlet.
Wait at least 30 minutes, this will let the printer to reset
Turn your ink cartridge upside down for 2 minutes before installing.
This will let some of the ink from the bottom to reach the printhead.
Plug printer back in and turn on and install ink cartridges.
This might work if your printer only detected a low ink condition at first.
For the scanner to work, the printer must have no alarm.
Jan 14, 2011 | HP PSC 1315 All-In-One InkJet Printer
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP 1315 printing real slow
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
Jun 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
Flashing light check print cartridge
You must replace all ink carts with new ones at the same time. Yeah, this how HP makes its money.
Jan 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
I have a new canon mp210 printer ink is low i bought new ink to replace old their is no ink cartridges in printer. When i look at the pictures to load new ink and put it in alarm light is flashing
Even if the ink level is low, you can continue printing.Press the paperfeed knob for 5 seconds. inklevel indicator will stop now.
Sometimes a new (or refilled) cartridge is not recognised correctly.
When one color is really mt, stop printing and replace inmideatly the colorcartridge.Printing or scanning without the 2 cartridges in place is impossible.
Dec 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP PSC 1315 All-In-One InkJet Print Cartridge Error
Hello -
Did you perhaps not mean to post under the 1315? I am not sure if you have this printer or another model. The 1315 normally takes a different number ink cartridge.
Meanwhile - gotta tell you that the 1315 is the buggiest printer I ever had. If you purchased it recently and can find your receipt, I'd take it back! Since they've pretty much done away with the 1315, if it was a recent purchase, it was likely a clearance item from some place.
Try taking all the ink cartridges out, uninstall the printer entirely, and reinstall it (the entire printer, not just the cartridges). Blow your printer out with canned air as well - dust, pet hair, people hair, fuzz and general paper fibers can build up more than we think, and cause error messages and other printing problems.
That should help, if it was the 1315 model.
That being said, note that if it still doesn't work, and you have the 1315, save yourself a lot of grief and toss it in the trash and buy another cheap printer! 1315 is Bug City!
Jun 07, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp 5550 printer
Here's A Trick you don't really have to buy a new cartridge if it a bit low but here how you do the trick.On the place where the ink leaks out dip some water on it with a paper towel and replace it back on the printer and guess what there's ink!
Apr 08, 2008 | HP DeskJet 5550 InkJet Printer
83 people viewed this question
Seeker5211
Seeker5211
