I have a hitachi big screen probably 5 years old - and it isn't working - but I can see the menu from the tv AND cable,and it has the letters YPBPR 3 on it in the upper right hand corner
  • 10,594 Answers
TV has been set on component video input-3 as display shows YPBR-3
Please press INPUT/ SOURCE button on remote repeatedly or press TV button on tv remote to set tv on tv input to watch tv channels.
If that does not solve your problem, please let me know with tv model number as it would be written at back of tv.
Thanks.
Posted on Apr 22, 2010
What is wrong with my TV's Ypbpr input???
is this the only input where the TV does this? what happens when you disconnect this source? May be your source.
If the TV does this no matter what input, perhaps you have some leaky caps on the power supply PCB,. These can usually be detected by their bulging tops & usually self replaced (if you have the wherewithall) at a cost of less than $10.00
May 08, 2014 | Hitachi Televison & Video
Sound comes on, no picture and YPBPR:3 coe comes up
tried with other component input like AV1 or AV2 doesn't work?.ok turn off the tv and unplugged it for a while to reset the power supply board.
Sep 23, 2012 | Hitachi 55HDS69 55 in. Plasma Television
I have lost the picture and instead get ypbpr:2 on the screen.
Change your INPUT selector until you get back to TV/cable input or til you get back to the input that your sattelite/cable box is hooked into on the TV.
Jun 14, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I plugged in the normal 3 Video inputs and it still doesn't work.
More info is needed, please. When you say 3 video inputs, what are you referring to? I believe the Sanyo has the HDMI, RGB/YPbPr component video, S-video component, RCA composite video and Coaxial connections, though I'm not sure how many of each. So lets start with the best quality to least.
HDMI: This is one cable that provides both audio & video and produces the best picture quality. It comes in different lengths and is a wide, flat connection. A must for 1080p resolution signals.
Component video, RGB or YPbPr analog component cables: 5 separate RCA cables, 3 of which are video that separate the video signal & 2 audio cables. The 3 video cables are generally red, green and blue (RGB) or marked individually with the letters Y, Pb/Cb & Pr/Cr . The audio cables are red & white. You may see these on the back of DVD players often. They will carry a signal up to 1080i but not 1080p.
S-video component: One cable for video, it is a round connection with several pins in it and will only plug in one way. You must use 2 RCA cables for audio with this cable, red & white again.
Composite video: 3 separate cables; Red, White & Yellow. Red & White are audio, left and right while yellow is video.
And finally there is coaxial which it the cable that is identical to the cable from the pole/ cable box or your dish. It is the poorest quality.
What can happen is you are using 3 standard RCA cables and have them plugged into the component input & they will not carry the signal, or one end in component input and the other end in the composite output or vice versa. Another is that you have the wrong input selected on the menu. Check all your cables and connections, plus the input you have selected on the TV itself.
Dec 09, 2010 | Sanyo 42 in. LCD TV
My TV is almost 5 years old. Barely used more
Howdy,
Sounds like the TV has lost the VIDEO and only has color. Make sure all the cables are secure and good. 2) Reset the TV by unplugging the TV or any BOX you have attached to TV. Unplug both from a/c for 3-5 minutes, plug back in and turn both on.
If no fix. Go to service Company that is Authorized and get an estimate, possible cost $450.00 +. Too many areas of concern to help you with particulars.
Good Luck, Big Irish.
Dec 02, 2009 | Hitachi 46F500 46" Rear Projection...
Lost sound on one side of Hitachi Big Screen
the audio amplifier inside the tv "blew up" after 8 years this is nothing unusual. my gut feeling is to hook up your surround sound for your audio. paying to fix this would cost $$$$
Jan 21, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Big screen TV corners of tv blue and red
I HAVE A 57" TOSHIBA REAR PROJECTION TV. HALF THE SCREEN HAS A BLUE TINT AND THE OTHER HALF IS CLEAR.
Jan 19, 2009 | Televison & Video
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 53sbx10b
Try the auto convergence feature of the TV. Press the button on the front of the tv and wait about 5 minutes....
Apr 27, 2007 | Hitachi 53SBX01B 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
