Question about Dell PowerEdge 2900 (becwdk1_2) Dual Core Intel Xeon 5110, 4MB Cache, 1.60GHz, 1066MHz FSB 80GB/2000... Server
Dell PowerEdge 2900...USB Keyboard and USB mouse stop working after opening applications. Seems like it dumps drivers for USB controllers. I've tryed a 2.0 hub..I've switch USB ports, switched to new keyboards and mice and it still does it. Have to reboot server and then switch USB ports and still every few days I loose them again. Running MS Windows Server 2003 R2 with service pack 2...... Any ideas
    Problem Solver:
  • 14 Answers
Is it possible this is where the problem started? When updating the controller...
http://support.microsoft.com/kb/906690
I was going to suggest opening event viewer either through Administrative Tools or bye typing eventvwr in the Run dialogue box. You will see one column on the left and one on the right. The one on the right shows errors and performed operations alike, when you click on an area in the left column.
You'll see an "Event" tab if you scroll to the right after clicking on "System" in the left. Any red Xs mean error. Double click or right click & select "Properties" to read the error. Highlight and type Ctrl+C to copy the text in the Description area and search Google for an answer, careful where you click, reading the address for the location of the site, looking primarily for the support.microsoft.com website for solutions.
Go to the keyboard & mouse manufacturer's website and download any new drivers. You might also find legitimate drivers on the Dell site for the Host controller, USB controller & mouse/keyboard. Make sure they're for your system/model/components. Reboot if asked and allow divers to install.
My vote...
You can then/also try uninstalling the Keyboard & mouse drivers and rebooting to safe mode, then uninstall the Controllers themselves. Reinstall on reboot to normal Windows and try using only certified drivers... or drivers that came with the mouse/keyboard or that you downloaded as instructed earlier.
Uninstalling and then reinstalling iIMHO is the best method rather than updating. Sometimes drivers overwrite and become corrupt.
Try to only stick with microsoft & Dell (your manufacturer) for driver updates. Programs that connect to sites and download new drivers for your system often install incorrect updates. Even if your system has a say, Toshiba AB-01234-YX, the driver for the component might not be written the exact same way Dell/the computer manufacturer has written it. You also do not know the programmer and cannot honestly say you can trust them when installing and asked "are you sure" if it is not digitally signed.
HTH.
Posted on Apr 23, 2010
Poweredge 2900 message E1000 and E1215 1.8v pwrgd
http://www.manualslib.com/manual/36871/Dell-Power-Edge-2900.html?page=19
Jun 30, 2013 | Dell POWEREDGE 2900 Server
When i press start button of dell poweredge 2900.the server display the dell logo for a long time.nothing to ahead and hang. whats the solution.
open the system and remove the ram clean the ram pins with an eraser and fix back. check if it works.
normally this happens due to ram connection or bad ram which needs replacement
Aug 30, 2012 | Dell POWEREDGE 2900 Server
Just bought Gateway ZX4951-33e and cannot get wireless keyboard or mouse to work.
click start control panel keyboard hardware then properties you should see driver details,you will have options to update driver,roll back driver,uninstall
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver(if applicable)
make sure the usb device is inserted correctly into the usb port (if applicable)
hope this helps
as for the mouse
make sure the lead has a secure seating if applicable or the usb device
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options also hardware under hardware you can troubleshoot or
select properties under driver you will have the options to update driver,rollback driver or uninstall and under hardware you can troubleshoot the device
hope this helps
May 31, 2011 | Computers & Internet
Keyboard & Mouse not inputting..Dell OptiPlex GX280.. OS, XP. Microsoft Wireless Desktop 3000 (keyboard/mouse) new.. Dell boots up and desktop appears, the cursor (arrow head) remains in middle of...
Check that batteries are charged and installed properly.--make sure driver disc is installed if applicable- check instructions as some wireless suites need you to push a small connect button to initialise them . Also try shifting the usb conector into another USB port if it is notm getting reconised.
I hope this helps
Andrew.A
Apr 09, 2011 | Dell OptiPlex GX280 PC Desktop
I do not believe my mouse is connected to the device. I turn on my desktop and the mouse and keyboard do not work, so I cannot even enter my password to log onto the desktop.
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
hope this helps
hope this helps
Feb 01, 2011 | Microsoft Standard Wireless Optical Mouse
I have Dell PowerEdge T300 server, running Windows 2003 SP2 after I finished the installation and every thing was ok, and the server reboot many times , the keyboard and mouse stopped working and I can't...
You will need the drivers for them i had a similar problem
insted of reinstalling windows i got a very old taty keyboard and mose from a windows 95 pc
and used them till i got and installed the drivers for them.
Dec 26, 2010 | Dell PowerEdge T300 Server
Ps2 keyboard and mouse don't work. usb works fine
Assuming you have checked in setup that the PS2 is turned on the other option is to re-flash the bios .
At some time someone switched the mouse and keyboard and started up the computer this can cause you to need to re-flash the bios most likely the keyboard chip needs to be replaced sorry to bring bad news .
Dell seems to have this problem yet the USB works is good where most modern keyboards and mouse are USB.
Purple is Keyboard if not color coded the closest to the outer side of case is the keyboard.
Good luck hope this helps you
PS. You may try setting the jumper pins to default the main board back to factory defaults then remove the jumper pin and leave off for first boot .When doing this be aware not to have the power cables connected to the server remove all power cords and the monitor . Prior to doing the first power up plug in the PS2 keyboard only then the monitor. Cross you fingers If you lucky your PS2 port’s will be working again if so shut down re install the jumper pin install the PS2 mouse.
Sep 24, 2009 | Dell PowerEdge 1600SC Server
Wireless keyboard and mouse not working, battery in receiver?
The receiver should not have a battery. It gets its power from the USB port. Try uninstalling both keyboard and mouse via (Control Panel...Device Manager) and reinstalling them. Sometimes the drivers get corrupted and reinstalling them will fix that. Also there are on/off switches on the mouse and maybe the keyboard. Check that someone hasn't turned them off to save batteries when not in use.
Sep 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
How to deactivate internal keyboard - Dell Inspiron 9400
if you go to the control panel, to hardware, in the keyboard section you should be able to uninstall the internal keyboards driver which will stop it working.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
Keyboard stopped working
you could try getting a USB to PS/2 adapter, if you have a PS/2 port on your computer. if it is a Dell made in that last 2-3 yrs ir probably doesnt have PS/2. its worth a shot tho.
PS/2 ports are usually Green and Purple. if you do have two, you might go to your local Radio Shack and see if they have any. Let me know if it works.
About the driver, there is no driver for the keyboard, except the generic USB keyboard driver in Windows.
If the keyboard is truly dead you might just go buy another one (or trie to get one from Dell, if its under warranty).
Feb 28, 2008 | Computers & Internet
Dell PowerEdge 2900 (becwdk1_2) Dual Core Intel Xeon 5110, 4MB Cache, 1.60GHz, 1066MHz FSB 80GB/2000... Server Logo
894 people viewed this question
Alun Cox
