Question about Maxtor Hard Drive
Jumper settings for a maxtor hd i need jumper setting from master to slave help thks model 71084a s/n j9027mfs
  • 3 more comments
  • Don1k Jun 08, 2008
    I have a Maxtor 30GB model 5T030H3 hard disk (IDE). I want to make it a slave drive. I bought a new Hatachi 80GB (IDE) 7200 RPM 8MB for my master hard disk.
  • bernard468 Jun 14, 2008
    I just need a pic of the master and slave settings for model number 32049H2 Maxtor ide HD
  • Anonymous Aug 21, 2008
    Como jumpear el disco como esclavo
  • Anonymous Sep 26, 2008
    i need to find out how the jumper setting on a maxtor 90841u2 hard
    drive to make it a slave drive because i want to recover the data and
    application that are in it
  • vankqriekend Apr 25, 2009
    I want to install the Maxtor 32049H2 N256 as slave Hd in my new computer how do I set the jumpers ?
  • 1,006 Answers
Here you have MANUAL'S
Posted on Mar 24, 2008
Posted on Sep 26, 2008
I have a maxtor H.D. model # 31024h1 , i cannot find the jumper settings to distinguish between master and slave
Typically, for older MAXTOR drives, put the jumper on the 2 pins closest to where the ribbon-cable connects, to set it to 'MASTER'.
Remove all the jumpers to set it to 'SLAVE'.
Aug 24, 2010 | Computers & Internet
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Setting Maxtor HD as Slave.
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Apr 23, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
Nov 29, 2008 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
May 15, 2008 | Maxtor Hard Drive
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Maxtor Hard Drive Logo
1,094 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
