Question about Canon imagePROGRAF IPF710 Printer
IPF710 Error code E161-403E Abnormally high printhead temperature
How do I fix this problem, the service manual only refers to the error code with no solution
3 Suggested Answers
SOURCE: Canon IPF 710 with error code E161-403E,
i want to delet cut orderwhile turn on
Posted on Oct 20, 2010
The error apeared when i stated to print !
How to solve it.
It is about 6 month since we started to use your product.
Posted on Jun 15, 2010
Error code 03130031-2618
It mean "Vh voltage error" and can be cause of short circuit in the printhead . Sometimes you can get good result with printhead changing, but it is not guarantied because of possible printer electric parts (carriage board, flat cable, motherboard or power supply) damage. For printhead changing, delete paper and use Service mode (hold Paper sourse + Information while switching printer on).
Apr 13, 2015 | Canon imagePROGRAF IPF710 Printer
Error 03800 500-280 C
Many nozzle on printhead did not inject .
You must clean your head or replace it. Or comes up in service mode
and check your nozzle check .For cleaning head you can take it out of printer and clean with head solvent, if not clears maybe u must replace print head.
Also check the canon ipf710 service manual from below link, it will save you money and time
Canon ipf710 service manual
http://goo.gl/e0h9OC
thanks
Nov 17, 2014 | Canon imagePROGRAF IPF710 Printer
Kyocera km 2540 error code C6150
Refers to an Abnormally low fuser thermistor edge temperature. Your machine could not warmup. Fixing error codes (C6xxx series) must be reset by a technician after clearing the cause of trouble. Reseting a fixing code without proper repair may result in fire or damage.
Sep 04, 2014 | Office Equipment & Supplies
Canon Ir2318 error code 00003
the code is related to the fuser section.If the machine is new then enter the service mode by pressing additional function and then * and clear it in error clear , if it is old machine then check the fuser for open thermistor,broken element .
Aug 24, 2011 | Canon imageRUNNER 2200
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
Solve Error 161-403E
Let it rest for a while, change print head.
Jun 15, 2010 | Canon imagePROGRAF IPF710 Printer
Canon IPF 710 with error code E161-403E, abnormally high printhead temperature how do I clear/remedy it?
How to solve it.
Apr 22, 2010 | Canon imagePROGRAF iPF8000 Printer
Error code c6300
The code C-630 indicates an abnormally high fixing temperature.
Check the thermistor, if it is shorted, replace.
the Fixing Heater Control Circuit is located on the power source PCB> relace as needed.
Apr 01, 2009 | Copystar CS-1820 Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
I560 error code 5200
Orange 10 5200 Replace the BJ Cartridge(Printhead)
Cartridge Overheat 8 x
7 times in orange/green 5200 Cause: The print head's temperature is abnormally high tnx and good day!!!!!
Apr 07, 2008 | Canon BubbleJet i560 InkJet Printer
Canon imagePROGRAF IPF710 Printer Logo
478 people viewed this question
old marine
old marine
