Question about Kitchen Ranges
Magic Chef 30" slide-in gas range-3 burners liting ok, the 4th just clicks. What could be the culprit?
  • 776 Answers
Most problems with the burner flame can trace back to the air shutter--the valve that assists in mixing air with gas to produce a flame. Some Magic Chef gas range models have a sealed-burner system that will not allow you to access under the range-top controls.
You will need to call a professional to have it fixed, or first on your own just check for debris on the pipe
Posted on Apr 22, 2010
Electric spark will not work, burners will not light
The spark electrode sends a spark to ignite the gas in the burner assembly. If the spark electrode is defective or worn out, it might not produce a spark, or the spark might be too weak to ignite the gas. As a result, the spark electrode will make a clicking sound when the burner is turned on, but the burner won't light. If the spark electrode is defective, replace it.
Mar 25, 2018 | Magic Chef Kitchen Ranges
Magic chef gas range top burners will not stay light
This problem is almost always due to a defective gas valve. If you decide to replace the part yourself remember safety 1st, turn off the gas and disconnect power to the range.
Nov 16, 2011 | Magic Chef Kitchen Ranges
I have a magic chef gas range top , a drop in , and the igniters are all clicking at once , started on their own. any help. ??? Larry
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Dec 13, 2010 | Magic Chef Ovens
My left front range has a spark and i didnt even turn it on it just did it by it self
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 30, 2010 | Magic Chef 30 in. 8241RT Gas Cooktop
Magic Chef gas range ignitor continually clicking
One of the burner control switches is shorted. If they are not overly expensive I replace all 4 while it is apart.
Eric
Feb 23, 2010 | Kitchen Ranges
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Model CGC2430 Magic Chef Cooktop ignition keep clicking
heatman101
Jan 01, 2010 | Magic Chef CGC2430 Gas Cooktop
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Oven goes on without being turned on
the control switch tripper problem that switch has to be replaced with a tripper.
Dec 15, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
