Kenmore 54501 Dehumidifier
Problem for Kenmore 54501 Dehumidifier
Fan not working
By bodmanj on Mar 22, 2008
When you hear the compressor, the fan will not operate.
Same Problem
May 10, 2009
-   Fan not working, thermal overload on compressor trips. Do I need a new fan?-   darjen
Apr 29, 2009
-   fan does not work. the fan motor hums. what should i do? -   Guest
Mar 17, 2009
-   Fan is not moving (just humming real loud). This seems to be a flaw on this model. Where can I get a replacement motor?-   craigte
Sep 22, 2008
-   My fan is also not working. I have removed every screw, but still cannot get at the fan motor. How does the metal surround come off without damage?
larryrich@aol.com
-   larryrich
Sep 03, 2008
-   I have exposed the condenser coils and the fan motor. Refrigeration is working but it is obvious that the fan is not. How do I know if the fan is bad or if it is not getting the proper command (or voltage) from the control board. I can remove the plug from the main control board; What voltages should I expect going from the control board to the female plug of the fan ? The leads are black, red and orange. -   fbcp
Solution #1
posted on Apr 05, 2008
Somewhat Helpful)
APP-TECH
Rank: Guru
Rating: 88%, 179 votes
THE FAN MAY OR MAY NOT HAVE OILING PORTS ON THE MOTOR. IF NOT, THE MOTOR NEEDS REPLACED. IF THERE ARE OILING PORTS ON THE FAN MOTOR, TRY SPRAYING SOME WD-40 IN THEM AND THEN ADDING SOME LIGHT MACHINE OIL TO THE MOTOR. THE OILING PORTS ARE SMALL HOLES AT EACH END OF THE MOTOR WHERE THE MOTOR SHAFT EXITS THE MOTOR HOUSING.
Was this helpful?
Yes
No
Solution #2
posted on Sep 04, 2009
Not Rated)
dave57078
Rank: Wiz
Rating: 83%, 12 votes
the fan motor operates on standard 110v household current... you can test the motor by hooking an extension cord with the female end cut off and the 2 wires stripped back 1/4 inch to the black and orange wires off the motor... wire nut black to black and white to orange then plug it in a standard outlet... if the motor is good it will run... then you know it's the board and you may as well scrap the dehumidifier... if the motor is bad replace it with a new motor...
easiest way is to simply cut in the middle of the wires from the motor and attach your extension cord this way... which ever is the problem (board or motor) you won't be reusing the motor anyway...
Was this helpful?
Yes
No
Popular Solutions for Kenmore 54501 Dehumidifier
Questions and Unsolved Problems for Kenmore 54501 Dehumidifier
Do you recommend Kenmore 54501 Dehumidifier?
Answer
Answer
when I turn it on, water doesn't gether in the bucket but comes out of the drose hose connection.... (More)
Answer
have a manual for Models MDF 30AE - 5OAE - 40AE & 65AE EVERY ONCE IN AWHILE THE... (More)
Answer
our dehumidifier is not collecting water
Answer
dehumidifier model # 54501800. I have red button that popped out when returning collection basin.... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 24, 2008
Fan on My lg LHD65EBL dehumidifier is not working it needs to be replaced. I have a replacement. I need help in replacing it.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 54501 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
