Question about HP OfficeJet K80 All-In-One InkJet Printer
I have never been able to do a document scan on this machine, when I scan, the text comes out barely legible and the papaer full of "dots", on the other hand, picture scanning works fine. Any ideas of what my problem is?
SOURCE: scanning document leaves streak down right hand side
Backu
Thanks for the tip...the problem is NOT a black line but a wide yellow line on the right side of the paper. It starts out about a quarter of the page in width and diminishes in size to about a half inch in width after many repeated scans.
The glass IS clean , and even when the glass had some smudges here and there, I never had a yellow stripe problem!
Scanner bulb is bright and even the entire length of bulb (no dark areas) so I don't think it is the bulb!
Rowboat
Posted on Dec 26, 2007
cariandco
  • 39 Answers
SOURCE: Scanning Problems
I would first make sure that you have latest driver update. MS Word is very particular about how it reads things back in. I would try saving the scan as a text file or PDF instead and then open them in Word. Hope this helps!
If this solution was helpful to you, will you please rate the solution? Thanks!
Posted on Aug 19, 2008
mrbench87
  • 40 Answers
SOURCE: scanning a document
i would like to know if you did completely install the printer software of this printer.if you did kindly locate the icon HP SOLUTION center,go to settings>>scan setting>>san to set-up>>restore to defaults.kindly check now if the front panel destination list has generated the options then click apply and OKAY.try to press now the scan button of the printer is the scan options are generated...
send feedback for further troubleshooting solution..
Posted on Aug 31, 2008
tborn6
  • 700 Answers
SOURCE: Scan as a PDF
you ned to open the digital imaging moniter and then set up the scannning to email button. If you have any questions drop me a line. Thaks for using Fixya.
Posted on Dec 23, 2008
  • 684 Answers
SOURCE: NEED OCR SOFTWARE FOR C3180 ALL IN ONE
www.softpedia.com/get/Office-tools/Other-Office-Tools/ABBYY-FineReader-OCR-Professional.shtml - 88k
U can Download it from the above Link
Good Luck
Posted on Apr 05, 2009
How can you scan using OCR it comes in unreadable do I need some other software installed to use the OCR function ?
On OCR software we can only scan a full text documents. Document that doesn't have any line, image, graphic. Try to scan a full text document and check if that will work.
Hope this helps. Rate if it works. Thanks
May 03, 2011 | Canon Office Equipment & Supplies
My MS Word 2007 has been giving me problems for about a week or so. It's part of MS Office Home and Student 2007. The problem is that it keeps freezing up on me and I lose typed text. Eventually I can...
Rename all instances of your document template files (Normal.dotm or Normal.dot). This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.Renaming the template will let you quickly determine whether the global template is causing the issue.
When you rename the Normal.dotm template in Word 2007 or the Normal.dot template in Word 2003 and in earlier versions of Word, you reset several options to the default settings. These include custom styles, custom toolbars, macros, and AutoText entries.
Jul 03, 2009 | Microsoft Office Professional 2007 Full...
Word text document not printing clearly on every line.
What version of Word do you have? What OS are you using?
Can you append a print to file to this thread so that I can see what data the printer is being sent?
May 09, 2009 | HP DeskJet 722c InkJet Printer
How do I scan and e-mail pdf documents from the MP730?
Scanners scan a document in picture format(JPEG) dot per dot. Their are complete programs out ther that will scan a document and turn it into a text fine. They are far more expensive that just copy a picture of some words on a page, Typical scanner function. I hope I have explained it well.
Feb 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Sep 21, 2008 | HP DeskJet 6122 InkJet Printer
SCANNING
Load the text document face down on the scanner glass.
Open the Lexmark Imaging Studio.
Click the Scan & Edit Text (OCR) button (shown below).
The All-In-One Center appears with the Scanning & Copying tab expanded.Click Preview Now in the upper right corner of the All-In-One Center. An image of the scanned document appears in the preview section.
Click and drag the box with the dotted lines to select a specific area of the preview image to scan.From the Select your text editor: drop-down menu, select a word-processing or text-editing program.Click Send Now.
Jun 18, 2008 | Lexmark All-in-One Printer with PictBridge
I need to scan a document to an MsWord file. my printer/scanner is MFC-465CN
Your printer needs to support OCR(Optical Character Recognition) and you need to have supported software that can scan.
OCR can only scan text that is only text and very legible. You will probably have to retype the document.
May 01, 2008 | Office Equipment & Supplies
How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Jun 25, 2007 | HP ScanJet 8270 Flatbed Scanner
HP OfficeJet K80 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
