Question about Car Audio & Video
DVD player model number DVP3982/37 Serial number KX1A0840465767 My DVD Video Player is failing to start the second disc in a series of 2. Thinking that it was the disc I bought a second copy but it will not start the second disc either. The day before both discs ran perfectly & the 2 first discs still work. When it fails to start I get this on the DVd player display 7:48:47 Help!
  • 661 Answers
This is an interesting problem that sounds like either a security failure or a laser alignment failure.
I would check it with numerous other video titles especially ones produced by the same people that made the one you are having trouble with. If it works fine with all other movies then the problem is most likely related to the security encoding they put on that disk.
Posted on Apr 22, 2010
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
Unlock the DVD player
follow the steps. God bless you
    • 1 Find the unlock code for the specific make and model of your DVD player. Unlock codes for more than 6,000 DVD player models can be found online at Videohelp.com (see the Resources section).
    • 2 Write down the unlock code for the make and model of your DVD player. The unlocking process can be as simple as a short number code, but on some DVD player models, the code is a complex series of numbers to enter and buttons to press.
    • 3 Turn on your DVD player. Remove any DVD that is in the unit.
    • 4 Enter the unlock code for your DVD player exactly how the code is listed. On some units, enter the code by using the remote for the DVD player. On others, you may need to enter the code on the unit itself or with a combination of the remote and the unit.
    • 5 Turn off the DVD player after you enter the code. When you turn the DVD player back on, the DVD player should be decoded and able to read DVD discs from any region.
Nov 13, 2012 | Televison & Video
Region error
see the procedure and fix it.God bless you
    • 1 Purchase or borrow an imported DVD. The only real reason to make your DVD player region-free is if you plan on watching imported DVDs.
    • 2 Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player.
    • 3 Have your remote handy. You will need your remote to enter the input codes into your DVD player.
    • 4 Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try DVD Exploder or Video Help (see Resources below). Both have an extensive list of codes for almost every kind of DVD player manufactured.
    • 5 Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number.
    • 6 Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open.
    • 7 Test your imported DVD to see if it works, once you have entered your code into the DVD player.
Oct 01, 2012 | Sylvania DV220SL8 DVD Player/VCR
Unit model D-C350/XSA only opens region 4 need to also to open region 2 DVD's
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
Cheers,
Scott
"If this has helped you, please be kind enough to leave a testimonial rating"
Jul 09, 2011 | Samsung DVD-C350 DVD Player
Region codes required for DVD's from England.
Hi its better to make your DVD region free,please follow these steps:The internet has made it easier to purchase obscure foreign movies on DVD that aren't sold in this country. DVD's have region codes so they will only play on certain DVD players. For instance, US DVD's are region 1 while Europe and Japan are region 2. The only way you can play a foreign DVD then is to purchase a region free DVD player or make your DVD player region free.
  • Get a DVD player. If you purchases a DVD player, make sure you purchase a DVD player that people have had success in converting to region free. If you already own a player, you will need to note down the make and model of your player.Step 2
  • Look up the DVD hack for your player. There are several sites that feature DVD hacks. Two popular sites are DVD Exploder and Video Help. Simply look up the make and model of your DVD player and check to see if there is a hack.
  • Jul 26, 2010 | Video Game Consoles & Games
    Region hack code for samsung dvd-p241
    You can try to use this tip, which is generally used for all these Samsung models: DVD-709,DVD-809,DVD-909,DVD-511,DVD-611,DVD-615,DVD-811,DVD-M105,DVD-M105 E,DVD-M108,DVD-M203,DVD-M204,DVD-M205,DVD-M305,DVD-M405,DVD-P233,DVD-V530. I think that P-241 is about the same of P-233, which is unlocked with this tip. You can try, and then answer me if worked.
    1. Make sure that there is no disc in the tray and switch on the player.
    2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
    3. You should see a set of language options. Release the PLAY and STOP buttons.
    4. Select your language.
    5. Press REPEAT then the following codes for the required region the player is already set to (region you bought the player in) do not confuse this with the A-B button:
    Region 1 - 2, 9, 3, 3, 4
    Region 2 - 3, 8, 7, 6, 7
    ("E series M105", M205 and M305 users try: 57538)
    Region 3 - 5, 6, 7, 3, 2
    Region 4 - 7, 6, 8, 8, 4
    Region 5 - 5, 3, 8, 1, 4
    Region 6 - 2, 4, 4, 6, 2
    6. A code will appear, indicating the region setting of your player.
    7. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
    8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
    9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
    On some models, you will have the ability to disable Macrovision, but you will have to turn off the Quasi-PAL option and set the SCART output type to Video rather than RGB.
    Jul 09, 2009 | Philips Magnavox MWD7006 DVD Player
    Dvd player gives unknown disc
    thats because its region locked..do the following:
    start the player without any DVD in it.
    open the lid.
    while the lid is open press 9,9,9,9,0
    you should see region 0 displayed.
    close the lid.
    Your DVD player is now region free.
    note:
    replace 0 with 1 to 6 at to set the wanted region number if needed.
    do let me know if it worked.
    Oct 29, 2008 | Philips DVP320 DVD Player
    Car Audio & Video Logo
    20 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
