Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice Maker The door, at the ejection portion of the fridge is not closing properly. Creating ice build up at drop part of the fridge. Freezes and does not let the ice come down. I need to know how to get the door frame off to be able to look at the workings to see what I might need for repair. Thanks Muchl
  • 110 Answers
Sounds like door is misaligned while both doors are closed is the gap even from top to bottom if not than make adjustments top and bottom serews, try to find out whats draging drawers not shutting all the way ect,ect
Posted on Apr 22, 2010
I have a Samsung RF265ABBP model. I just finished replacing the ice maker kit and everything works fine. I noticed Ice build up on the left side of the sliding door. It builds up on the fridge itself and...
Could be a gasket problem. But, also on those sliding doors, ice can cause them to not properly close all the way! Pull the door all the way open and check the track/rails for ANY ice. Make sure it is completely free of ice!
Oct 11, 2013 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
The ice maker stopped ejecting ice. Now no water going to icemaker
hav u cleared the ejection area for any debris and the like?
Jun 14, 2008 | Frigidaire FRS23H5AS Side by Side...
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Continuous beeping
Either any door is not closed properly or door sensor is not working,its not sensing the door closed.Or the problem is no defrost.The defrost is causing over ice in fridge or freezer section.
Reset the refrigerator by disconnecting it from wall outlet for 12 hours,then reconnect and see if still the same problem is there.
On some cases its issue with fan not working.There are two fans,one in freezer section and one in fridge section.If either of the fan is not working the controls will flash.
These will help.
Thanks,.
Dec 22, 2012 | Fisher and Paykel Active Smart E522B...
Why is green light flashing
Its indication of overfreezed fridge or freezer unit.Or any door not getting closed properly.
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Model gd25dfxfw00 Gold side by side; air appears to be leaking around the ice maker ejection door creating a build up of ice inside the freezer at the bottom of the icemaker ejection slot.
I had the same problem, same Whirlpool frig.
There's damper/delay arm/plunger, similar to what you see on doors, that slowly closes the ice door to allow all the ice to escape. This is stuck/broken. You can order the parts on line and replace it. I actually just removed it and the door closes nice and snug again, and no more ice build up in the chute. It occasionally traps ice in the chute, as the door shuts real quick now, before the last cube(s) can come out. I'm use to it now and am quick to open the door without sending more ice out of the maker.
The replacement kit should be : AP3595356
May 21, 2010 | Refrigerators
Ice maker will not make ice cubes, only crushed ice.
take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Jan 20, 2010 | Frigidaire FRS23H7C Side by Side...
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice machine freezes up
Is the ice freezing on the surface of the tongs? You may be pulling in moist air from the outside of the fridge.. check all the door seals to make sure no air is getting in. What is the model number of the unit so I can pull up a diagram?
Dec 27, 2006 | Maytag 22.6 cu. ft. Side-By-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
67 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
