Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
Alpine amp not working.
I have two alpine pdx-1.1000s that just stopped working in the middle of a song. the fuses in the amps are all good. the light on the top is on. the fuse in my 0 gauge wiring kit is also good. i checked all the rca cables behind the cd player and going in to the amps. i know a lot about car audio and this has me stumped. did something burn up in side the amp?
  • 175 Answers
Possably, did you get it professionally fitted? they have lifetime warranty on install,
Posted on Apr 27, 2010
Alpine pdx-m12 blue light fiashing
If the blue light is flashing it means the output mosfets are taking more than what the power supply can deliver. Probably just one of the MOSFETs is bad. Take off the heavy aluminum bar that is the heatsink for the 8 MOSFETs. Turn it on for about 10 seconds. (And see that the blue light is flashing.) Find the (hopefully) one MOSFET that is hot. Replace it. And you're good.
Aug 10, 2012 | Alpine PDX-M12 Car Amp
I just install my new setup ,i have 1 pdx f4 ,1 pdx m12 and 2 sub 10''type r and my pproblems is when i put a song the pdx f4 lights become red and my mid and tweeter cut ...
Disconnect all speaker leads from the PDXf4 - test. If the amp turns on and says on ok - then turn off, and attach one speaker lead at a time until it turns off. When it does check that speaker and the speaker wire to see if it is blown, shorted out etc.
Feb 06, 2011 | Alpine PDX-F4 Car Amp
How do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
Mar 20, 2010 | Alpine PDX-4.100 Car Audio Amplifier
PDX 1.1000 amp overheating?
Hello thefatman69e,
The Alpine PDX-1.1000 is a physically small amp to produce the power that it does. The result is that it has less physical area for heat to dissipate. Running at or near it's maximum output into a 2 ohm load, it needs some serious airflow to keep it cooled down. I'd look for some way to get more air to it.
Hope this helps.
Sep 21, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
I had 3 subs hooked up to my pdx 1 1000 and it stopped playing one day and hasnt played since
1. check your B+ wire and make sure the fuse is good, and your ground wire and are you certain that the remote turn on is good?
2. If you have 3 subs runninng on the amp i hope those subs are 8ohms and you wired them in parelell to give an impedance of 2ohms. Let me know. Mark @ Sounds Good to Me.. tempe, az
Mar 18, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine pdx-1.1000
what is happening is the amp can draw the current. u need a capacitor
Apr 11, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
406 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
