Question about HP D4360 DeskJet Printer InkJet
My printer only prints one copy.. - HP D4360 DeskJet Printer InkJet
How do I make copies
What do you mean by copies? Like printing 1 page in more than 1 copy?
In the Print dialog box (when you click the File => Print command), You can increase the number of copies to be printed in just one printing.
If your printer is multi-function (one printer that can scan, copy, and print), just place the document to be copied (photocopy) in the scanner tray, cover it and then PRESS the OK. In some models, it is MONO or COLOR under START button group.
Feb 06, 2010 | Office Equipment & Supplies
Unable to cop
You can not use the copy feature if your printer is "printing". You can scan while other is printing simply because scanning is not using the printer's print heads. Therefore if you are printing, you can not copy at the same time.
Is your printer printing OK? So you should be able to copy as well. Press COPY button when the printer is ready. Basically, you have the Copy (Black) and Copy Color options. If you have 1 option only, pressing COPY makes you choose black or COlor using the keypad selector. Just choose any option and press OK or START.
Nov 20, 2009 | HP Officejet J5780 All-In-One InkJet...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Need to print more than one copy
If your printing from Windows, when the print dialogue box comes up look for the option number of copies. Change that to the specified number you want to print out and then hit print.
Jun 13, 2009 | Canon PIXMA IP3500 Photo Inkjet Printer
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
CX7400 Epson printer will only print one copy at a time
If you are printing from your computer, in the print options select how many copies you would like to make in the preferences.
Feb 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Sep 16, 2008 | HP LaserJet 1320 Printer
Will not print copies
printing from indesign, the page goes through to printer, printer receive light flashes, but the page come out.
May 14, 2008 | HP LaserJet 5550 Printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP D4360 DeskJet Printer InkJet Logo
103 people viewed this question
Seeker5211
Seeker5211
