Question about HP OfficeJet 7410 All-In-One InkJet Printer
The printer is saying the ink cartridge is not
The printer is saying the ink cartridge #96 is not properly installed
  • 68 Answers
SOURCE: Ink cartridge (not) installed properly
Did you make sure that the colored tape was removed from the back of the ink cartridges? The manufacture puts the tape on there to protect the circuits during shipping. If the tape is still there it would not be able to communicate with the printer or computer.
Posted on Sep 19, 2007
Mix-it-up
  • 832 Answers
SOURCE: brothers 420 cn printer question
Unplug mfc from power! Take carts out. Wait three minutes then plug powercord in again. Power up mfc. Wait until machine demands carts. Set carts in. If aksed by machine answer display: Press 1 for YES (new cart) repeat until all carts are reinsert. NEVER change carts when its displayed NEAR EMPTY! Only at EMPTY. Should work!
Posted on Oct 01, 2007
SOURCE: HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Posted on Aug 04, 2008
SOURCE: will not print - ink cartridges not recognised, not installed properly etc
we had the same problem...please help!!!!
Posted on Sep 04, 2008
sagarjd
  • 95 Answers
SOURCE: Printer won't print properly.
Please perform the following steps:
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Print Cartridges and then press OK . An alignment page prints.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page.
Regards,
Sagarjd
Posted on Nov 21, 2008
I wanted to print my documents here but my printer always says that the ink cartiledge is not properly installed and i already reinstalled my canon printer pixma ip1200
Make sure the ink cartridge is properly installed. Or this is probably common problem with Cannon ink cartridge, replacing the cartridge will solve the problem, but you need check it first under maintenance on Control Panel.
Aug 06, 2011 | Canon PIXMA iP1200 Photo Printer
Installed new ink cartridges mx 300, compatible B&W 40, color 41, printer status still says low ink, printing as if it is low ink. properly installed, tape removed, what i miss? can I check something...
Do you know what?. As a matter of fact,it is not compatible cartridges you buy. It is refurbished cartridges that repackaged with other brand as if this is their product. I say it is original cartridges that once empty and repackaged. So that's why when you install the cartridge the ink level stays low. You can make it sure by comparing it with new original cartridge. Find original cartridge,may be you can borrow from someone,which ink level still full and install on your printer. I am a hundred percent sure ink level will show properly :).
Feb 19, 2011 | Canon MX300 Office All-In-One Printer
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed or the ink cartridges are not installed properly
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Jun 26, 2010 | Canon PIXMA MP160 All-In-One Printer
Red light blinking. screen says . color ink cartridge is missing or not installed correctlly . install ink cartridge. but the ink cartridge is in
take out the color cartridge out of the printer clean/wipe the cartridge terminal with a tisuue paper same with the contact point of the cartridge from the printer..properly connect the cartridge properly to the printer.be sure that the cartridge snaps in..
May 20, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
The printer says that the black ink cartridge is bad. Replace
Please use HP 94 or HP 96 black ink cartridge.
Regards,
Rizwan.
Mar 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
New black ink cartridge - Machines says No Cartridge
just clean the place where your ink is installed clean it with cotton and alcohol..try to reinstall your ink slowly and make sure it contacts properly..hope this works...ITTech7574
Aug 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
E5 problem
E5, says the ink cartridges are the wrong type, not properly installed, or not installed at all. You can't refill those without replacing the chip or resetting the chip. Many refilled cartridges just don't work...
Aug 27, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E5 error
HI ...
This error comes in when the cartridge is not installed correct ... I would suggest you remove and then re-install the cartridge using the below steps:
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
Please vote if this helps ... Cheers :)
Jul 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink cart error
Is there a metal wire (clip) hooked on black plastic in the ink carriage? If not, these are notorious for breaking the small plastic hook....when broken, the cartridge is not held in proper postion so printer won't recognize that the ink cartridge is installed......no replacement parts are available for this series of printers.
Jun 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
