Question about Hitachi 53UDX10B 53" Rear Projection Television
I have a 53 inch hitachi ultravision #53UDX10B Its out of focus and when you press the magic focus button it trys then pops up with the # 4 in the corner is this a convergence problem or what ?
  • pm98 Apr 22, 2010
    the #4 is green in the lower righthand corner
    Novelist:
  • 132 Answers
Yes, you have a convergence failure. Usually requires replacement of 2 X STK ICs and any burnt resistors associated with the function that is faulty.
Look at the user menu and compare with images on our Convergence Gallery. Try to adjust in the convergence adjust menu. Identify the functions that do not work and make note. When you replace the ICs, pay special attention to the low ohm resistors for the non-working function. They will be located near the colored plug associated with the non-working function. If red vertical will not adjust, check resistors near the red plug.
There are many posts and websites that offer "new and improved Convergence IC substitutes. My advice is to use the original part numbers and replace any burnt resistors with original values. Many ICs purchased on the Internet are very poor quality and do not work. Many users get substitute replacement ICs and never get their TVs working again.
If you have other electronics repair experience, this job may be done with some chance of success. If you have no experience, there are many secondary problems that can and usually do appear. Determining how to fix the secondary faults and how to correctly align the TV is difficult without prior convergence repair experience.
Some of the common problems encountered are:
1. Poor solder techniques, resulting in damaged PC boards or poor solder connections.
2. Poor quality or wrong parts installed and recognizing this problem.
3. Resistors open or burnt. Some resistors are weakened by the initial faulty IC. Replacing with a "good" IC and starting the TV causes the weakened resistors to burn up. IC may be ok but there are one or more open resistors that measured ok when ICs were being replaced.
4. Wrong ICs used, causing resistors to burn up.
5. Resistors that measure normal and become faulty when heated by current flow.
6. Recognizing that convergence circuit is repaired correctly and alignment is needed.
7. Major alignment in service menu required because data is corrupted by multiple tries of magic focus or manual adjustment while faulty circuit conditions exist.
8. Major alignment required because user adjusted centering rings or physically changed mechanical focus adjustment, then mis-adjusted convergence settings trying to correct mechanical alignment faults.
9. User has not connected plugs and connectors correctly and caused secondary damage or mis-alignment trying to correct secondary issue.
Physically replacing the ICs may appear simple but recognizing if a fault still exists or if correct repair is required causes many attempts at repair to fail. Keep it simple. Replace with good quality original part numbers, measure suspect resistors and adjust only what is necessary.
There are only 3 things to fix, IC failure, resistor failure and user induced secondary faults. Data processor and memory is bulletproof.
easyab
Posted on Apr 22, 2010
Out of focus and the magic focus will not finish and give a 4 on the botton right of the screen
Hitachi tv magic focus will not finish and the picture is out of focus, what part needs to be replaced?
Jan 05, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I have a hitachi ultravision and the blue is off center.
your convergances amps ics have failed and need to be replaced alone with the 2 burnt resistors you will find then run magic focus
Nov 30, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
Oct 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Double image after magic focus with a number 4
Replace Both Of your convergence ICs STK392-110 they are big black IC will have part# on them Call Mats for parts 1-800-628-1118
Sep 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Is there a Magic Focus function on 53XDF01B?
The correct model is 53fdx01b. There is a mogic focus button on the front of the set. Procedure for Chassis DP05F, DP05, HP11, HP12:
1. Press and hold the DIGITAL ARRAY or CONVERGENCE ADJUST button on front panel.
2. While the button is held down, then press the INPUT or ANT button on remote control.
3. The unit will now be in the DCAM.
NOTE:
1. Proceed with digital convergence adjustment.
2. Remember to save the correction data.
3. Units with MAGIC FOCUS only - Failure to initialize MAGIC FOCUS sensors after saving
convergence correction data will result in a STATIC (+) display when MAGIC FOCUS attempts
to run. The technician will then be required to access the service only switch behind the front
cover to get back into the DCAM to initialize the sensors, since the procedure to access DCAM
without removing the front panel, requires MAGIC FOCUS to be running.
4. To exit, press the POWER button on the front panel.
Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My hitachi 53udx10b tv is out of focus.
rojamon,
That #4 error is listed as "overflow," and I got a"ROM overflow" errorwhen I tried to save my adjusted convergence data.I don't know whatthat all means yet, but if I figure out my problem,I'll post backhere. I've read here and elsewhere that the out-of-focusproblem comesfrom bad resistors or amps on the convergence board. Youcan tryservice mode to adjust convergence. Press the Magic Focusbutton, andthen press it again to stop it, and then press the Statusbutton onyour remote. Here's a link to the manual convergence procedure (scroll down).
Dec 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi tv, model 53udx10b
Sounds like you need to run Magic Focus.
Sep 22, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
681 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
